In total there are 21 users online :: 0 Registered, 0 Hidden and 21 Guests :: 2 Bots
Overheating  Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Overheating  Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Overheating  Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Overheating  Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Overheating  Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Overheating  Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Overheating  Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Overheating  Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Overheating  Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Overheating  Vote_lcapOverheating  Voting_barOverheating  Vote_rcap
 Overheating
Yotehunter66
rob1
10 posters
rob1
Overheating  Empty
PostSubject: Overheating    Overheating  Icon_minitimeWed May 01, 2013 10:16 am
I know this has been a popular subject . Ok here is what i have . While doing some cleaning i noticed i had a wore spot in my drivers side rad hose. So i changed it. Ever since then rhino gets hot and spits out overflow hose. I did NOT bleed the system . I just added water & anti freeze back to rad. I am thinking i just need to bleed it but not positive that is what is wrong.
Overheating  Empty
PostSubject: Re: Overheating    Overheating  Icon_minitimeWed May 01, 2013 10:44 am
Yes, bleed the system!
It helps if you fill out your profile so we know what model you have.
The 660 has 2 bleeder screws, one one the head and the other on the water pump.
Overheating  Empty
PostSubject: Re: Overheating    Overheating  Icon_minitimeWed May 01, 2013 10:45 am
I agree, you have to bleed the system.
rob1
Overheating  Empty
PostSubject: Re: Overheating    Overheating  Icon_minitimeWed May 01, 2013 10:48 am
Sorry , i updated my profile . Its a 06 660 . I am thinking thats all it is since it didnt do it before i replaced hose just wanted to make sure. Now i jack front end up fill radiator with cap off start it up let it run open bleeder and keep rad full ? Is this the way to do it ?
Overheating  Empty
PostSubject: Re: Overheating    Overheating  Icon_minitimeWed May 01, 2013 11:09 am
You can jack it up if you want, start it and crack upper screw until you get a steady flow of coolant.
Where was your worn spot on the hose? Where.the engine cover hits it? If so, trim the inner lip on the cover. I've seen a lot of the hoses rub in that area. Yamaha did add a sleeve on the hose but it still hits there.
Overheating  Empty
PostSubject: Re: Overheating    Overheating  Icon_minitimeWed May 01, 2013 11:40 am
i never run mine while bleeding them..anti freeze expands when as it gets hot so you wanna fill it cold..
rob1
Overheating  Empty
PostSubject: Re: Overheating    Overheating  Icon_minitimeWed May 01, 2013 12:03 pm
ok so i should fill up rad engine cold & not running , open bleeder on top of water pump housing ? The hose actually had a wors spot from the front driveshaft . It looks like there was a holder that wasnt fastened or the hose had worked loose from it.
rob1
Overheating  Empty
PostSubject: Re: Overheating    Overheating  Icon_minitimeFri May 03, 2013 4:57 pm
bled the system and seems to be good !
Overheating  Empty
PostSubject: Re: Overheating    Overheating  Icon_minitimeFri May 03, 2013 6:07 pm
give this stuff a try. i swear by it. i have been running it sense 04 i had a grizzly that was overheating dealership told me to put it in my grizzly w/ 28" tires never overheated after the swap. sense then i have put it in everything i have.
http://www.liquidperformance.com/motorcycle/performance/racing-coolant-antifreeze/
Yotehunter66
Moderator
Yotehunter66
Overheating  Empty
PostSubject: Re: Overheating    Overheating  Icon_minitimeFri May 03, 2013 7:35 pm
Burp that baby. Dancing Banana
Overheating  Empty
PostSubject: Re: Overheating    Overheating  Icon_minitimeFri May 03, 2013 7:53 pm
This stuff and Engine Ice both work great but are both expensive and a pain in the ass to run. You can't mix it with water so you're forced to carry a jug with you at all times...and where I live you can't buy it anywhere. I ran it last season but flushed it this year because of this.
Overheating  Empty
PostSubject: Re: Overheating    Overheating  Icon_minitimeFri May 03, 2013 9:48 pm
I just use dexcool
AZredrhino
AZredrhino
Overheating  Empty
PostSubject: Re: Overheating    Overheating  Icon_minitimeSun May 05, 2013 5:02 am
my fan stopped working so I replaced it with a new fan with a shroud. never bleed or burped it. and never overheats now. when I got the new fan it ran backwards blowing out the front. Had to cut wires and reverse them. it was strange. maybe the put the connector on backward at the factory
Overheating  Empty
PostSubject: Re: Overheating    Overheating  Icon_minitimeSun May 05, 2013 8:45 am
had to bleed system when I installed my heater no over heating problems
Overheating  Empty
Overheating
» My console in my rhino is getting very very hot but not overheating
» JBS T4 Overheating Fix - Radiator Shields
» 700 Water Pump Issue ... Overheating
