| Trying New tire | |
+14honda450sfm Deuces wild Snorhino flimmy REDRHINO64 madmax 1 KJrhino thekevin gullyjumper CUSTOMIZEDRHINO13 T.Rhino mike734 WV Hot Rod Rhino Firefighter 18 posters |
| Subject: Re: Trying New tire Sat May 11, 2013 3:08 am | |
| There's nothing like 4 new Mr. Feelgoods. Thanks for sharing the measurements, that's important and hard to find out about tires. 15 psi sounds like a good idea in a 14" tire, and they look like they have a nice wide footprint mounted and aired up. If they wear good and a strong, that is one hell of a deal for those. I would imagine that once word gets out and sales increase, the price will go up quickly. | |
RiverRat
| Subject: Re: Trying New tire Sun May 12, 2013 10:54 am | |
| Those big horns had 3000 miles? Nice to know. When it comes time I will be going that route for sure. They still had a little meat left on them. | |
| Subject: Re: Trying New tire Sun May 12, 2013 11:28 am | |
| Wore out Dunlops, 589's and now I have some Big Horn knock offs, 3,000miles. | |
| Subject: Re: Trying New tire Sun May 12, 2013 11:38 pm | |
| Put about 100 miles on the new tires Saturday / Sat night. They perform identical to the Big Horns. The only differences I have found so far is they are a hair taller than same size BH's and they seem to be a little stiffer. Started out with 12psi in the front and 16 in the rear. No tire bulge and a little rougher ride. Dropped to 10 and 14. A lot better ride and just a little bulge. I dropped the pressure on the trail with a cheap gauge so I'm not real sure on the pressure.
Very interesting thing I found when I mounted them.
When I aired them up for the first time, I put 16 psi in all of them. That is what I ran in my BH's. I noticed when I set them side by side the fronts were about an inch taller...HHHmmmm
I played with the air pressure until I got them all the same size. Ended up with 4 psi less air in the front. Got home and looked it up in the manual and sure enough it calls for like 9 and 13 psi. 4 psi difference in the front and rear.
For reference , fronts are 26x9-14 and rears are 26x11-14 | |
| Subject: Re: Trying New tire Mon May 13, 2013 12:32 am | |
| Nice, got any pics of them mounted yet? | |
| Subject: Re: Trying New tire Mon May 13, 2013 1:02 pm | |
| - CustomizedRhino13 wrote:
- Nice, got any pics of them mounted yet?
First page of this thread, about half way down..... | |
| Subject: Re: Trying New tire Mon May 13, 2013 1:11 pm | |
TBONE21
Posts : 139 Join date : 2013-03-10 Age : 43 Location : High Point, NC
| Subject: Re: Trying New tire Mon May 13, 2013 1:20 pm | |
| them tires look good. | |
| Subject: Re: Trying New tire Thu May 16, 2013 6:14 pm | |
| Larry, during your research did you happen to look at duro power grips if so what did you thank ? | |
| Subject: Re: Trying New tire Thu May 16, 2013 6:55 pm | |
| - T.Rhino wrote:
- Larry, during your research did you happen to look at duro power grips if so what did you thank ?
I did ! They are like $10 or $15 a tire cheaper than BH's and look really good, but if You read on the description all of the 14 in are only 4 ply. That was the deal changer for me. | |
| Subject: Re: Trying New tire Thu May 16, 2013 7:02 pm | |
| - Firefighter wrote:
I did ! They are like $10 or $15 a tire cheaper than BH's and look really good, but if You read on the description all of the 14 in are only 4 ply. That was the deal changer for me. BTW I am still very impressed with the artrax I bought. $100 cheaper and despite what a few others have said, they are identical to the BH's | |
| Subject: Re: Trying New tire Thu May 16, 2013 9:35 pm | |
| UPDATE !! My riding buddy liked my new tires so much, He ordered an identical set. Mounted them yesterday and found a flat today. Aired it up and found 3 pin holes in the tread........... | |
| Subject: Re: Trying New tire Thu May 16, 2013 10:02 pm | |
| doh ....thats not good. i looked at em on motosport and it says they no longer carry that tire. | |
Deuces wild
| Subject: Re: Trying New tire Thu May 16, 2013 10:03 pm | |
| Holes from the factory, or ran over something thin ply? | |
Deuces wild
| Subject: Re: Trying New tire Thu May 16, 2013 10:05 pm | |
| Mike what are doing on here shouldn't you be putting on that cage? | |
| Subject: Re: Trying New tire Thu May 16, 2013 10:16 pm | |
| Subject: Re: Trying New tire Thu May 16, 2013 10:19 pm | |
| - lambfam660 wrote:
- Mike what are doing on here shouldn't you be putting on that cage?
my ass is draging. | |
| Subject: Re: Trying New tire Mon May 20, 2013 12:18 pm | |
- UPDATE !! My riding buddy liked my new tires so much, He ordered an identical set. Mounted them yesterday and found a flat today. Aired it up and found 3 pin holes in the tread...........
Looked like factory defect. Called Motosport and sent pics. They told Him to keep tire and they are sending a new one.... A+ Put another 100 miles on the new tire this weekend. They are definitely stiffer than a Big Horn. I have mine down to 10 psi and My riding Bud has His down to 9 psi, just to make them squat a little. I was running 15 - 16 psi in my BH's | |
| Subject: Re: Trying New tire Mon May 20, 2013 12:42 pm | |
| glad they took care of it | |
| Subject: Re: Trying New tire Mon May 20, 2013 2:47 pm | |
Put another 100 miles on the new tire this weekend. They are definitely stiffer than a Big Horn. I have mine down to 10 psi and My riding Bud has His down to 9 psi, just to make them squat a little. I was running 15 - 16 psi in my BH's Wow they sound like a better tire! Looking forward to seeking how any miles you get out of them. | |
| Subject: Re: Trying New tire | |
| Trying New tire | |
