| Subject: primary fixed sheave Thu May 09, 2013 2:21 pm | |
| working on getting to one way bearing to flip over where I put in wrong, the new bump in road is the primary fixed sheave will not slide off when I worked on it before I remember it just coming off , have pulled on it pretty hard don't want to brake any thing. any one have idea on what could be holding it thanks for info | |
sls666
| Subject: Re: primary fixed sheave Thu May 09, 2013 3:08 pm | |
| it is alot softer metal i think then your shaft so it might be binding i used some wd-40 to get mine off and it worked fine. i also put a dab of copper kote antiseize on it so it would not do it again | |
| Subject: Re: primary fixed sheave Thu May 09, 2013 3:32 pm | |
| they usally come right off...hopefully not stripped.. | |
| Subject: Re: primary fixed sheave Thu May 09, 2013 9:56 pm | |
| splines where bad had to use slide hammer to finally get it off please send one James will call in the morning about it | |
| Subject: Re: primary fixed sheave | |
