| Two holes on primary and secondary cover | |
4x4ff
| Subject: Two holes on primary and secondary cover Tue May 28, 2013 12:38 pm | |
| On the primary and secondary cover there are 2 holes that apparently mate up with the cage over the clutch. There is nothing in there nor was there when I bought it used. The manual shows a plug cover or something there but doesn't say anything about it. What should go there and is it ok to leave it open??
Steve | |
4x4ff
| Subject: Re: Two holes on primary and secondary cover Tue May 28, 2013 12:48 pm | |
| I should add that I cannot find anything for this in the parts breakout. The repair manual shows something like a plug but doesn't say anything about it. It appears that it has a brass insert in it. It is NOT the holes for the bracket for the air intake either. That is in place as it should be.
Steve | |
| Subject: Re: Two holes on primary and secondary cover Tue May 28, 2013 1:34 pm | |
| the two holes that mate up with cage, need bolts to secure , there's a drain on bottom of cover the bolts are same size as cover but shorter | |
4x4ff
| Subject: Re: Two holes on primary and secondary cover Tue May 28, 2013 2:46 pm | |
| OK, thanks. I'll go try to find some bolts.
Steve | |
| Subject: Re: Two holes on primary and secondary cover Tue May 28, 2013 2:54 pm | |
| this is on a grizzly, but it shows the bolts and plug. Very similar | |
4x4ff
| Subject: Re: Two holes on primary and secondary cover Tue May 28, 2013 3:00 pm | |
| Yes....the ones I am talking about are the ones in the center above the drain.
Steve | |
| Subject: Re: Two holes on primary and secondary cover Tue May 28, 2013 3:12 pm | |
| Mine was missing one also when I bought it. It will let water in ! | |
4x4ff
| Subject: Re: Two holes on primary and secondary cover Tue May 28, 2013 3:49 pm | |
| Do you remember what length? | |
| Subject: Re: Two holes on primary and secondary cover Tue May 28, 2013 4:03 pm | |
| About a half to 3/4 in..I think. | |
4x4ff
| Subject: Re: Two holes on primary and secondary cover Tue May 28, 2013 4:12 pm | |
| Thanks for the info!!!
Steve | |
| Subject: Re: Two holes on primary and secondary cover Tue May 28, 2013 4:13 pm | |
| You can just take one of the other cover bolts and match it up. Thats what I did. | |
4x4ff
| Subject: Re: Two holes on primary and secondary cover Tue May 28, 2013 4:14 pm | |
| Subject: Re: Two holes on primary and secondary cover Tue May 28, 2013 4:20 pm | |
| Yes, but not much. seems like I had one just like the other cover bolts and I put a couple washers on it. My is a 660 and I dont know if there is a difference. | |
| Subject: Re: Two holes on primary and secondary cover Tue May 28, 2013 4:21 pm | |
| The bolt are about 20-25 mm long,6 mm diameter and have 12 mm head with an integral washer, I believe it is a Japanese metric thread.APPROX.
Last edited by 123.bert0621 on Tue May 28, 2013 6:13 pm; edited 1 time in total (Reason for editing : MORE) | |
4x4ff
| Subject: Re: Two holes on primary and secondary cover Tue May 28, 2013 4:28 pm | |
4x4ff
| Subject: Re: Two holes on primary and secondary cover Tue May 28, 2013 11:02 pm | |
| FYI....
Went to the hardware store and 6mm X 20mm Worked perfectly!!! | |
| Subject: Re: Two holes on primary and secondary cover Tue May 28, 2013 11:13 pm | |
| Subject: Re: Two holes on primary and secondary cover Wed May 29, 2013 6:30 pm | |
| Right-on | |
| Subject: Re: Two holes on primary and secondary cover Wed May 29, 2013 6:39 pm | |
| - 123.bert0621 wrote:
- Right-on
Thanks Bert ! You really know Your rhino stuff !!! | |
| Subject: Re: Two holes on primary and secondary cover Wed May 29, 2013 7:59 pm | |
| Welcome | |
| Subject: Re: Two holes on primary and secondary cover | |
