In total there are 15 users online :: 0 Registered, 0 Hidden and 15 Guests :: 2 Bots
Thoughts on drilling slide air bleed to 1/8 inch holes Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Thoughts on drilling slide air bleed to 1/8 inch holes Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Thoughts on drilling slide air bleed to 1/8 inch holes Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Thoughts on drilling slide air bleed to 1/8 inch holes Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Thoughts on drilling slide air bleed to 1/8 inch holes Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Thoughts on drilling slide air bleed to 1/8 inch holes Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Thoughts on drilling slide air bleed to 1/8 inch holes Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Thoughts on drilling slide air bleed to 1/8 inch holes Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Thoughts on drilling slide air bleed to 1/8 inch holes Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Thoughts on drilling slide air bleed to 1/8 inch holes Vote_lcapThoughts on drilling slide air bleed to 1/8 inch holes Voting_barThoughts on drilling slide air bleed to 1/8 inch holes Vote_rcap
jaydog13
thekrust
slomo
7 posters
slomo
slomo
Thoughts on drilling slide air bleed to 1/8 inch holes Empty
PostSubject: Thoughts on drilling slide air bleed to 1/8 inch holes   Thoughts on drilling slide air bleed to 1/8 inch holes Icon_minitimeWed May 29, 2013 8:32 pm
Has anyone drilled out their carb slide air bleed holes and modified the spring? If so how did you like it and do you have to rejet for this mod or is it not worth the effort thanks
thekrust
thekrust
PostSubject: Re: Thoughts on drilling slide air bleed to 1/8 inch holes   Thoughts on drilling slide air bleed to 1/8 inch holes Icon_minitimeWed May 29, 2013 8:50 pm
I did mine - trying to get past the mid range lean stumble with the snorkle on it, didn't really seem to change much but haven't had it on a good tour yet. It should be better tho even if not fully cured.
jaydog13
PostSubject: Re: Thoughts on drilling slide air bleed to 1/8 inch holes   Thoughts on drilling slide air bleed to 1/8 inch holes Icon_minitimeWed May 29, 2013 8:54 pm
I love it but I have a 3" snorkel. don't know how it will work without. start with a 3/32 on one hole try it then the next hole. if you like it try one hole at 1/8. I had to take both of mine to 1/8, what a difference. went from a hesitation on bottom to spinning on asphalt on bottom
ALBANATE
PostSubject: Re: Thoughts on drilling slide air bleed to 1/8 inch holes   Thoughts on drilling slide air bleed to 1/8 inch holes Icon_minitimeWed May 29, 2013 9:18 pm
Would not recommend doing it unless your intake dictates it. Can be a nightmare to get tuned on a stock airboxed rhino.
Nate
Alba Racing
PostSubject: Re: Thoughts on drilling slide air bleed to 1/8 inch holes   Thoughts on drilling slide air bleed to 1/8 inch holes Icon_minitimeWed May 29, 2013 9:44 pm
X2 on Nate, I did mine for the snorkel issues , i drilled both of mine to 1/8 stuntman Mike may chime in
slomo
slomo
PostSubject: Re: Thoughts on drilling slide air bleed to 1/8 inch holes   Thoughts on drilling slide air bleed to 1/8 inch holes Icon_minitimeThu Jun 06, 2013 12:08 am
Thanks for the replies, will leave stock for now
thekrust
thekrust
PostSubject: Re: Thoughts on drilling slide air bleed to 1/8 inch holes   Thoughts on drilling slide air bleed to 1/8 inch holes Icon_minitimeThu Jun 06, 2013 1:08 am
So after riding again with holes drilled I'm going to say if you have a 660 with snorkel's...drill them out and enjoy. It fixes those goofy probs and seems to be da chit! Will continue to go from here if anything negative comes up will let you know.
Not snorkeled...don't go here!
slomo
slomo
PostSubject: Re: Thoughts on drilling slide air bleed to 1/8 inch holes   Thoughts on drilling slide air bleed to 1/8 inch holes Icon_minitimeThu Jun 06, 2013 9:59 pm
Thanks not snorkelled yet
PostSubject: Re: Thoughts on drilling slide air bleed to 1/8 inch holes   Thoughts on drilling slide air bleed to 1/8 inch holes Icon_minitimeWed Jun 12, 2013 10:32 pm
Pretty much only needed when you run a snorkel.
PostSubject: Re: Thoughts on drilling slide air bleed to 1/8 inch holes   Thoughts on drilling slide air bleed to 1/8 inch holes Icon_minitimeWed Jun 12, 2013 11:02 pm
Well I jumped the gun and drilled mine. I have no snorkel and really don't plan too, unless someone figures out nice clean setup. I really can't tell much difference, only maybe when at idle, it doesn't seem to idle as well as before drilling. I did replace the throttle cable (local guy had a brand new spare for 20 bucks, sold his rhino) and it did make a HUGE difference. Response is awesome and it revs so quick now. I did try adjusting, but never could get to WOT with having too high of idle. I have about 2600 miles on it and the cable had stretched a good bit over time. Recommend replacing cable on a machine with that many miles or less (I guess), BIG DIFFERENCE!
» Proper way to bleed air from cooling system
» What is everyones thoughts on the new Wildcat Trail
» Two holes on primary and secondary cover
» adjustable seat slide
» Adjust carburetor slide on 04 660 rhino
