In total there are 30 users online :: 0 Registered, 0 Hidden and 30 Guests :: 1 Bot
Proper way to bleed air from cooling system Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Proper way to bleed air from cooling system Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Proper way to bleed air from cooling system Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Proper way to bleed air from cooling system Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Proper way to bleed air from cooling system Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Proper way to bleed air from cooling system Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Proper way to bleed air from cooling system Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Proper way to bleed air from cooling system Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Proper way to bleed air from cooling system Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Proper way to bleed air from cooling system Vote_lcapProper way to bleed air from cooling system Voting_barProper way to bleed air from cooling system Vote_rcap
4 posters
4x4ff
4x4ff
Proper way to bleed air from cooling system Empty
PostSubject: Proper way to bleed air from cooling system   Proper way to bleed air from cooling system Icon_minitimeSun Jun 16, 2013 8:12 pm
What is the proper way to bleed air from the cooling system on a 700??
I bled air from the top by the thermostat but didn't know about the lower bleed screw at the water pump.  Just not sure what the correct procedure is.
Steve
PostSubject: Re: Proper way to bleed air from cooling system   Proper way to bleed air from cooling system Icon_minitimeSun Jun 16, 2013 8:20 pm
Good question and good timing I just recived some great advice on here about a cooling issue I was having it would be nice to here to make sure I did it correctly.
PostSubject: Re: Proper way to bleed air from cooling system   Proper way to bleed air from cooling system Icon_minitimeSun Jun 16, 2013 10:22 pm
When I bleed my cooling system, I would first remove the lower bleed screw at the lower right near the water pump. Fill the radiator watch for the coolant to flow out the lower screw hole, then reinstall screw. Remove the screw at the thermostat, top up the coolant and start the engine run the engine watching for the coolant flow when the bubbles are gone or reduced reinstall the screw torque the bolts to 7ftlbs top up the coolant replace the cap and top up the overflow bottle. When cold check the radiator  level and look at the overflow level. I always did mine with the front of the rhino elevated thinking that it helped. 50/50 coolant is best, any stronger is a waste.
PostSubject: Re: Proper way to bleed air from cooling system   Proper way to bleed air from cooling system Icon_minitimeMon Jun 17, 2013 10:31 am
Great info thanks for the help.
4x4ff
4x4ff
PostSubject: Re: Proper way to bleed air from cooling system   Proper way to bleed air from cooling system Icon_minitimeMon Jun 17, 2013 11:24 am
What he said!!!!
Steve
PostSubject: Re: Proper way to bleed air from cooling system   Proper way to bleed air from cooling system Icon_minitimeFri Jun 21, 2013 8:46 pm
that's the ticket
» Thoughts on drilling slide air bleed to 1/8 inch holes
» I need a cooling fan.
» engine cooling!!!
» Stock cooling fan draw on a 660
