In total there are 33 users online :: 0 Registered, 0 Hidden and 33 Guests :: 2 Bots
Fuel gauge?? Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Fuel gauge?? Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Fuel gauge?? Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Fuel gauge?? Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Fuel gauge?? Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Fuel gauge?? Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Fuel gauge?? Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Fuel gauge?? Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Fuel gauge?? Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Fuel gauge?? Vote_lcapFuel gauge?? Voting_barFuel gauge?? Vote_rcap
 Fuel gauge??
Spanky
Chief1979
Djbison
10 posters
Djbison
Djbison
Fuel gauge?? Empty
PostSubject: Fuel gauge??   Fuel gauge?? Icon_minitimeMon May 13, 2013 2:35 am
My dash doesn't have a fuel gauge an I'm just curious if there is a easy way to put one on mine with or without changing the cluster??
Fuel gauge?? Empty
PostSubject: Re: Fuel gauge??   Fuel gauge?? Icon_minitimeMon May 13, 2013 6:52 am
fuel gauge kit from auto zone or some place like it. they are pretty cheap but take some cutting and work to get them set up right.
Chief1979
Fuel gauge?? Empty
PostSubject: Re: Fuel gauge??   Fuel gauge?? Icon_minitimeMon May 13, 2013 9:55 am
I found this cruising amazon for rhino parts. http://www.amazon.com/Kelch-54-1815-13-5-Gauge-Gas/dp/B002SA0SCA
I have not used this product, but am doing some research. I think I might pull the trigger on it and see how it works.
Fuel gauge?? Empty
PostSubject: Re: Fuel gauge??   Fuel gauge?? Icon_minitimeMon May 13, 2013 10:35 am
Heres a review on it, that's why I didn't but it. pale
False Advertisement, November 9, 2012
By
Frank W. Kiszely - See all my reviews
Amazon Verified Purchase(What's this?)
This review is from: Kelch 54-1815 13.5" Gauge Gas Cap (Automotive) I requested a Yamaha Rhino gas gauge. When it arrived it did not fit the threads of the Yamaha and appears to be for a portable gas can!
Help other customers find the most helpful reviews
Was this review helpful to you? Yes No
Chief1979
Fuel gauge?? Empty
PostSubject: Re: Fuel gauge??   Fuel gauge?? Icon_minitimeMon May 13, 2013 11:12 am
Thanks for the info. McKay. I guess that seals the deal for me, I'll just have to keep opening the cap to check. LOL
Fuel gauge?? Empty
PostSubject: Re: Fuel gauge??   Fuel gauge?? Icon_minitimeMon May 13, 2013 11:16 am
here is one for about $40....not bad for a real gauge that you can see from the seat
Fuel gauge kit
Spanky
Spanky
Fuel gauge?? Empty
PostSubject: Re: Fuel gauge??   Fuel gauge?? Icon_minitimeMon May 13, 2013 5:08 pm
I put this set up in mine with no problems so far
Gauge
Sending Unit
Fuel gauge?? Empty
PostSubject: Re: Fuel gauge??   Fuel gauge?? Icon_minitimeTue May 14, 2013 12:45 am
I don't know much about this at all, but isn't the float and everything already in the tank of the rhinos with no factory guage pod? I thought if you buy the pod and hook plug it in you had a fuel gauge and everything. If this is true, a automotive type electic fuel gauge should wire up.
Fuel gauge?? Empty
PostSubject: Re: Fuel gauge??   Fuel gauge?? Icon_minitimeTue May 14, 2013 7:03 am
It may be on the newer ones hump...but i dont think that is the case on the older 660's. I could be wrong but i have never seen one on my rhino.
JBFIREMAN
JBFIREMAN
Fuel gauge?? Empty
PostSubject: Re: Fuel gauge??   Fuel gauge?? Icon_minitimeTue May 14, 2013 8:28 am
I think its only on the 2008 and newer ones,and SE mld. Look on the top of tank for the sending unit
Fuel gauge?? Empty
PostSubject: Re: Fuel gauge??   Fuel gauge?? Icon_minitimeTue May 14, 2013 10:27 am
x2
Fuel gauge?? Empty
PostSubject: Re: Fuel gauge??   Fuel gauge?? Icon_minitimeThu May 16, 2013 10:14 am
Black Rhino has a gauge kit that works awesome! The kit comes with everything needed, including a wiring harness. They use a marine sender that is adjustable and doesn't have the float bouncing around in the tank. Install is very easy! I've been running their kit for 6 plus years with no issues.
Brian lee Rhino450
Brian lee Rhino450
Fuel gauge?? Empty
PostSubject: Re: Fuel gauge??   Fuel gauge?? Icon_minitimeThu May 30, 2013 9:20 pm
Been talking to jason at black rhino, and although the 450 is not listed for this kit. He is thinking an 11in. Float with the kit will work for the 450. Im ordering this kit next week. Jason said if the 11in. Float is too long he will get me a shorter one. Just a little info for the 450 guys if they were interested in this kit for their ride. Ill post up and let everyone know what works on the 450 when im done.
Fuel gauge?? Empty
PostSubject: Re: Fuel gauge??   Fuel gauge?? Icon_minitimeThu May 30, 2013 9:42 pm
It is not as bad as all that. Directly behind the passenger's legs, under the seat, there is a sight window cut through the panel. This allows you to see the front surface of the tank. I put a bank of red LEDs on the opposite end of the tank that shines through the tank. The fuel funnels the light better to the front surface of the tank than does the air above the fuel, which ends up making the fuel glow much brighter than the air. The top of the fuel is very visible in the sight window. It makes for a decent visual look-see that is much safer than a match in the gas cap opening. cherry
Fuel gauge?? Empty
PostSubject: Re: Fuel gauge??   Fuel gauge?? Icon_minitimeFri May 31, 2013 12:56 am
Great idea on the light, I'm used to shaking the rhino and tilting my head just right. lol!
Fuel gauge?? Empty
PostSubject: Re: Fuel gauge??   Fuel gauge?? Icon_minitimeFri May 31, 2013 1:00 am
Actually, that works no matter what. Even when the battery is dead. Laughing
Fuel gauge?? Empty
Fuel gauge??
» Gauge install
» Help with lc-1 afr gauge
» Gauge ??
» Which gauge are you using?
» A/F Gauge Needed?
