In total there are 29 users online :: 0 Registered, 0 Hidden and 29 Guests :: 2 Bots
tuning carb Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
tuning carb Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
tuning carb Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
tuning carb Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
tuning carb Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
tuning carb Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
tuning carb Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
tuning carb Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
tuning carb Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
tuning carb Vote_lcaptuning carb Voting_bartuning carb Vote_rcap
 tuning carb
5 posters
tuning carb Empty
PostSubject: tuning carb   tuning carb Icon_minitimeWed May 15, 2013 3:38 pm
trying to get carb tuned , got the idle-low side good 12.4 , bottom/mid a little rich 11 , mid/top richer 9.8, w.o.t. goes super lean 15--16
I going back up to 160 main next, my question is do I need a smaller pilot jet the moose kit I have had the needle with the grooves when I started it was on the next to bottom I now have it next to top groove trying to lean out the mid am I thinking wright on this
tuning carb Empty
PostSubject: Re: tuning carb   tuning carb Icon_minitimeWed May 15, 2013 5:17 pm
I have had better luck running the stock Yamaha needle than the aftermarkets
ALBANATE
tuning carb Empty
PostSubject: Re: tuning carb   tuning carb Icon_minitimeWed May 15, 2013 5:52 pm
A moose kit is just a dynojet kit. I would recommend going back to the stock needle. That needle sucks.
Stock needle with all shims and washers below the clip.
Nate
Alba Racing
tuning carb Empty
PostSubject: Re: tuning carb   tuning carb Icon_minitimeWed May 15, 2013 7:19 pm
I put the 160 main back in got rich ,on the way back to shop I took the air box lid off an snorkle thinking it would lean out a little instead it got richer , that just f--d up all my thinking decided I need a cold one an walk off before I be a tuning carb 592698436 on this sombitch will start over later
tuning carb Empty
PostSubject: Re: tuning carb   tuning carb Icon_minitimeWed May 15, 2013 8:06 pm
ok finished 1st cold one got 2nd an been pondering this shit , first I think I need to make sure slide is working right, because if its not this would cause being rich
second, I think I will set up with open air box then see what snorkel does to it will try to get 3in for snorkel before it goes back on
ALBANATE
tuning carb Empty
PostSubject: Re: tuning carb   tuning carb Icon_minitimeWed May 15, 2013 8:13 pm
Cold ones help... By removing the aibox lid you have now taken away the vacuum that lifts the slide. It will no longer be able to lift correctly and can drastically effect air fuel. Remember that you can only flow as much air as your greatest restriction.
Nate
Alba Racing
tuning carb Empty
PostSubject: Re: tuning carb   tuning carb Icon_minitimeWed May 15, 2013 8:25 pm
Jeff, Sorry I didnt have time to take a pic of the 3" snorkel, putting out fires all day. Nate is right you need the air box lid for proper vacum for the slide to work. That's why on the 720 you really have to run 3" snorkel.
tuning carb Empty
PostSubject: Re: tuning carb   tuning carb Icon_minitimeWed May 15, 2013 10:38 pm
ok will put back on in moring after I get back from bone doc, but that explains
why it got richer when I took off the lid, that helps out the pondering a lot
tuning carb Empty
PostSubject: Re: tuning carb   tuning carb Icon_minitimeThu May 16, 2013 1:35 pm
ok got home and going to start again , starting with air box lid on snorkel off
will recheck an set from low idle to w.o.t. see if this changes things
jaydog13
tuning carb Empty
PostSubject: Re: tuning carb   tuning carb Icon_minitimeThu May 16, 2013 1:50 pm
you to need to state rich also so put the needle high like 2 size bigger pilot and main and should be running rich all the way through then. that way u have a starting point because your a/f reading are all over the board.
tuning carb Empty
PostSubject: Re: tuning carb   tuning carb Icon_minitimeFri May 17, 2013 12:20 pm
with the air box lid on an no snorkel is very rich in middle an will lean out on the top , I think the slide is the main deal believe its slow on opening making rich in middle an when w.o.t. it opens an it goes lean . I went down to 160 main trying to help the rich right before w.o.t. an in turn made the top lean out , going to try to get smaller pilot jet sizes an a 162.5 main , I 've already drilled the slide to 1/8 on both holes , slide has some scratches /wear marks on side may see about new slide to see difference
jaydog13
tuning carb Empty
PostSubject: Re: tuning carb   tuning carb Icon_minitimeFri May 17, 2013 2:02 pm
The slide not opening quick enough will make it lean. Lowe your needle. One shim
tuning carb Empty
PostSubject: Re: tuning carb   tuning carb Icon_minitimeFri May 17, 2013 3:55 pm
Jeff, sounds like your getting close, Stick with it and you will be smoken Rzr's for lunch! tuning carb 2016508534
tuning carb Empty
PostSubject: Re: tuning carb   tuning carb Icon_minitimeFri May 17, 2013 7:30 pm
thanks Mike been trying every thing with this , Jason when it leans out it is w.o.t. which should have the needle all the way out of jet an in turn if I raise the needle it would make the middle-upper more rich before w.o.t. I think this is right , but I agree that there's something up with slide . Trying to locate more jets now
tuning carb Empty
tuning carb
» Temperature & Carb tuning??
» Anyone with Carb tuning Experience?????
» Tuning 660
» tuning in benchmark fcr41
» 450 Carb Jet Kit
