In total there are 18 users online :: 0 Registered, 0 Hidden and 18 Guests :: 2 Bots
Changing Belt in the Field Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Changing Belt in the Field Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Changing Belt in the Field Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Changing Belt in the Field Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Changing Belt in the Field Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Changing Belt in the Field Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Changing Belt in the Field Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Changing Belt in the Field Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Changing Belt in the Field Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Changing Belt in the Field Vote_lcapChanging Belt in the Field Voting_barChanging Belt in the Field Vote_rcap
5 posters
chammons
Changing Belt in the Field Empty
PostSubject: Changing Belt in the Field   Changing Belt in the Field Icon_minitimeTue Jun 11, 2013 7:21 pm
Hey fellas, I'm curious if you guy ever changed your Rhino belt in the field, Is there a trick to doing it? Getting the nut off seems to be the deal breaker as I can see. but maybe there's a trick I don't know about.
chalkminer
chalkminer
PostSubject: Re: Changing Belt in the Field   Changing Belt in the Field Icon_minitimeTue Jun 11, 2013 8:26 pm
cordless impact... Very handy in those situations!
PostSubject: Re: Changing Belt in the Field   Changing Belt in the Field Icon_minitimeTue Jun 11, 2013 8:49 pm
I may be wrong but I don't think I pulled either sheave the last time I pulled it off I had a bolt I believe it was a 6 mm to expand the secondary and rolled it off after you remove the cover and such? Someone will chime in let's see if I'm full of it mines a 700
PostSubject: Re: Changing Belt in the Field   Changing Belt in the Field Icon_minitimeTue Jun 11, 2013 9:54 pm
dont have to take the nuts off ....just open the secondary with a 6mm bolt...use oem belts and have straight faces and shouldnt have too..lol
SWN
PostSubject: Re: Changing Belt in the Field   Changing Belt in the Field Icon_minitimeMon Jul 22, 2013 1:07 am
I replaced one of the primary cover bolts with a really long one. That way, when I use a bolt from the primary cover to spread the sec sheave, I don't have to remove the fan from the sec sheave. If you use the stock length bolt from the primary cover to spread, the fan prevents the bolt from going in deep enough.
» Drive Belt ?
» what belt to go with
» belt burning up.. need help
» Belt question
» 1st belt slip?
