In total there are 35 users online :: 0 Registered, 0 Hidden and 35 Guests :: 2 Bots
Inner cv install Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Inner cv install Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Inner cv install Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Inner cv install Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Inner cv install Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Inner cv install Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Inner cv install Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Inner cv install Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Inner cv install Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Inner cv install Vote_lcapInner cv install Voting_barInner cv install Vote_rcap
 Inner cv install
2 posters
Brian lee Rhino450
Brian lee Rhino450
Inner cv install Empty
PostSubject: Inner cv install   Inner cv install Icon_minitimeTue Jun 11, 2013 11:14 pm
Anyone know of any vids for this. There are many for outer cv's. Cant find any for the inner. Only thing im confused on is the snap ring. This is my first time, i have rear axles off both inner and outer apart. I have the rhino manual and have seen pics of the order it all goes together. When i got the inners off the snap ring was just laying in the cup. So does the bearing go on the axle first then snap ring on axle then the cup? Need some guidance. And does the star(inner piece of bearing) tapered sides face eachother on the axle. Like taper on outer bearing faces taper on inner bearing. Question
chalkminer
chalkminer
PostSubject: Re: Inner cv install   Inner cv install Icon_minitimeWed Jun 12, 2013 12:00 am
here is a thread from the "other" site, it has a couple pics and some directions.
http://www.rhinoforums.net/how/67536-axle-help-needed.html
I just repacked and re-booted a rear inner for the first time. I did not notice the star part being tapered... Oh well I guess I have a 50-50 shot at getting it right. I put the bearing on the axle shaft first, and put the snap ring on the axle before putting it into the cup. The hardest part was getting the axle nut off.
Brian lee Rhino450
Brian lee Rhino450
PostSubject: Re: Inner cv install   Inner cv install Icon_minitimeWed Jun 12, 2013 12:24 am
Thanks man, axle nut i use large impact. Guess i should of said tapered end of the bearing cage do they go on first?
chalkminer
chalkminer
PostSubject: Re: Inner cv install   Inner cv install Icon_minitimeWed Jun 12, 2013 12:49 am
Oh yes, the tapered end of the cage goes towards the axle.
Brian lee Rhino450
Brian lee Rhino450
PostSubject: Re: Inner cv install   Inner cv install Icon_minitimeWed Jun 12, 2013 1:43 am
Got it thanks
Inner cv install
» 450 cam install
» Head install
» Gauge install
» My review on my Cam and MSD install
» Big bore install
