In total there are 32 users online :: 0 Registered, 0 Hidden and 32 Guests :: 1 Bot
painless 70207 install Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
painless 70207 install Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
painless 70207 install Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
painless 70207 install Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
painless 70207 install Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
painless 70207 install Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
painless 70207 install Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
painless 70207 install Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
painless 70207 install Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
painless 70207 install Vote_lcappainless 70207 install Voting_barpainless 70207 install Vote_rcap
3 posters
painless 70207 install Empty
PostSubject: painless 70207 install   painless 70207 install Icon_minitimeWed Jun 12, 2013 7:58 pm
just wanted to see if anyone has some pics and tips on there install will be wiring mine up fri or sat and putting the juice to that new 40" led light bar, I know quite a few of yous have the 70207 so lets see your pics and how bout your input steve s
Brian lee Rhino450
Brian lee Rhino450
PostSubject: Re: painless 70207 install   painless 70207 install Icon_minitimeWed Jun 12, 2013 9:07 pm
I really like mine. I run 4 gauges off of it. Cant post pics cause im at work but if u look in members rides my post is (my 450) there are a couple pics under the hood of my setup. I just welded a plate on the left front frame rail to hold it
Brian lee Rhino450
Brian lee Rhino450
PostSubject: Re: painless 70207 install   painless 70207 install Icon_minitimeWed Jun 12, 2013 9:10 pm
Instruction are very straight forward. Wish they made something like this for motorcycles usually i have to make my own harness
Last edited by Brian lee Rhino450 on Wed Jun 12, 2013 9:12 pm; edited 2 times in total (Reason for editing : Spelling)
PostSubject: Re: painless 70207 install   painless 70207 install Icon_minitimeWed Jun 12, 2013 10:25 pm
You can see where I mounted mine to the left of the cooler and above the battery. The circuit breaker and ground block is mounted inside the battery box.
https://hotrodrhinoforums.forumotion.com/t955-under-my-hood?highlight=Under+my+hood
» Painless Fuse Block Install
» Painless fuse block
» 450 cam install
» Inner cv install
» My Stereo Install
