Who is online? | In total there are 27 users online :: 0 Registered, 0 Hidden and 27 Guests :: 1 Bot None Most users ever online was 207 on Tue Jun 11, 2013 11:13 pm |
| | JBS sheave and OD weights installed ! Couple ???s | |
bl8tant
Posts : 3 Join date : 2013-06-12
| Subject: JBS sheave and OD weights installed ! Couple ???s Sun Jun 23, 2013 1:00 am | |
| Installed Thursday and finally got a chance to try it out today. I bought this 08 700 Rhino used a few weeks ago. I am new to the Rhino so I had a couple questions: 1) When I first bought it, top speed was about 26-30mph. That didn't seem right, so I talked to JBS (THANKS James!). So I installed the JBS sheave, OD weights,anti-friction washers, and a new yamaha belt. Today, In a level field I was able to hit 36 before I had to slow down. So I took it out on a quiet paved road....I was able to hit 49mph going downhill then the rev limiter kicked in. Does that seem like a reasonable top speed for the mods I've done ??? 2) I LOVE the bottom end with the new sheave and engine braking is WAY better. I guess there's no question here, just a happy observation. 3) I installed new front wheel bearings, and then took the front gearbox back to the dealer where I bought it to get all new bearings put in. Turns out it maybe didn't need them (the right side axle still has some up and down play where it enters the gearbox). Has anyone else ever noticed that there is some play in their gearbox where the axle enters?? I know they did the bearings cause I talked to the tech and he showed me the bearings that came out (which looked fine). 4) Are all rhinos this noisy ? Like everyone says...James and Nikki were great to deal with and it was nice to meet them in person. Very happy with all the aprts I got from them. James - Thanks for the stickers and can cozy ! Now you just need to start selling T-shirts (my neighbor has a heat press and makes custom shirts/hats if you need a "local" source. | |
| | | ASPENDELLROVER
| Subject: Re: JBS sheave and OD weights installed ! Couple ???s Sun Jun 23, 2013 2:35 am | |
| what size are your wheels and tires? do you have a windshield? mine only does 51 but its a slow stocker..lol | |
| | | scottwv
| Subject: Re: JBS sheave and OD weights installed ! Couple ???s Sun Jun 23, 2013 10:25 am | |
| YES , they are all this noisy...now ya havta do some type of stereo and amp install , so you can "drown-out" the bike noise with tunes !! You are right where you should be as far as your top speed is concerned...I think mine would do 48/49 on the level , before the msd . Being "local" to the JBS compound , is kinda a "blessed-curse"...you've only begun to spend $$ ... btw...Welcome to the forum !!! | |
| | | T.Rhino
| Subject: Re: JBS sheave and OD weights installed ! Couple ???s Sun Jun 23, 2013 12:54 pm | |
| Scott is rite once you get start you just can't stop. And James & Nikki being so nice just makes it easier to come addicted. Lol. | |
| | | ooben
Posts : 12 Join date : 2013-03-25 Location : Northern Idaho, God's Country!
| Subject: Re: JBS sheave and OD weights installed ! Couple ???s Thu Jun 27, 2013 1:12 pm | |
| " Has anyone else ever noticed that there is some play in their gearbox where the axle enters??" Is this what you are seeing? Right axle wobble"I know they did the bearings cause I talked to the tech and he showed me the bearings that came out (which looked fine). " Did the bearings they showed you look like #15 and #14? I ask because there is another bearing located in the housing #8 that actually supports the right axle. As far as I can tell, that bearing can't be replaced because a shaft is peened into the housing that is in the way of getting the bearing out. I think you have to replace the whole housing..... | |
| | | WV Hot Rod Rhino Admin
| Subject: Re: JBS sheave and OD weights installed ! Couple ???s Thu Jun 27, 2013 5:43 pm | |
| 190.00 to get that one...i have one | |
| | | bl8tant
| Subject: Re: JBS sheave and OD weights installed ! Couple ???s Fri Jul 05, 2013 11:25 pm | |
| I'm not sure as I just gave them a quick glance. If that other bearing is that expensive and hard to replace, I can guarantee they didn't do that one. The kit they installed was only like $70. The axle still has the same small amount of play as before, but at this point I think I'm just going to ride it and wait.....
I've done a lot of wrenching on the thing already and my other projects are eating up all my time.
Thanks for making me aware of the "mystery" bearing. At least when I decide to go back and redo their work I can go ahead and get the bearing and have it on hand. | |
| | | ooben
| Subject: Re: JBS sheave and OD weights installed ! Couple ???s Mon Jul 08, 2013 3:31 pm | |
| I don't think you can get just the bearing, I think you have to replace the whole housing. When I had my front end apart I could see a shaft that carries the 4WH drive locking lugs? that is peened into the housing, not sure if you could get that out without destroying the housing..... | |
| Subject: Re: JBS sheave and OD weights installed ! Couple ???s | |
