| Flooding issues | |
| Subject: Flooding issues Sun Jun 30, 2013 10:39 am | |
| Rhino started spitting and sputtering at high RMPs and backfiring on deceleration. I changed the fuel filter hoping it was the issue but sort of knew it wouldn't help. I went for a ride yesterday and it progressively got worse and stalled out five or six times...then quit altogether. Had to get towed home. I can smell the fuel so I'm pretty sure it's flooding out.
I'm going to start with changing the plug and cleaning out the carb...any other suggestions? | |
| Subject: Re: Flooding issues Sun Jun 30, 2013 10:41 am | |
| stopped up jet or flywheel key.... | |
| Subject: Re: Flooding issues Sun Jun 30, 2013 11:12 am | |
| Flywheel key? That would cause it not to fire correctly hence the flooding? Am I on the right track here? | |
| Subject: Re: Flooding issues Sun Jun 30, 2013 11:30 am | |
| Subject: Re: Flooding issues Sun Jun 30, 2013 1:24 pm | |
| - Pokahpolice wrote:
- Flywheel key? That would cause it not to fire correctly hence the flooding? Am I on the right track here?
right...its always the 2nd thing we check after carb | |
| Subject: Re: Flooding issues Wed Jul 03, 2013 8:03 pm | |
| Yanked the carb broke it completely down and cleaned everything. Also put in a new plug and tried the stock CDI. Got it to start, run solid at idle and mid RPMs but it completely cuts out at high RPMs and then kicks right back in once the RPMs come down a bit.
Any suggestions? | |
Yotehunter66 Moderator
| Subject: Re: Flooding issues Wed Jul 03, 2013 8:41 pm | |
| Sounds like it may be starving for fuel. Have you checked your fuel pump for flow? Could the vent line from the carb be plugged? | |
| Subject: Re: Flooding issues Wed Jul 03, 2013 8:43 pm | |
| Subject: Re: Flooding issues Wed Jul 03, 2013 8:57 pm | |
| Clean air filter? When mine gets dirty it runs terrible! | |
| Subject: Re: Flooding issues | |
| Flooding issues | |
