In total there are 20 users online :: 0 Registered, 0 Hidden and 20 Guests :: 1 Bot
belt issues Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
belt issues Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
belt issues Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
belt issues Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
belt issues Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
belt issues Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
belt issues Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
belt issues Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
belt issues Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
belt issues Vote_lcapbelt issues Voting_barbelt issues Vote_rcap
 belt issues
Yotehunter66
txgrown1404
7 posters
txgrown1404
txgrown1404
belt issues Empty
PostSubject: belt issues   belt issues Icon_minitimeSat Aug 10, 2013 8:27 pm
i just installed my new JBS sheave and im having issues getting the belt to ride back up to the top of the secondary.  im in neutral and I cant get the primary to spin freely to work the belt back up.  is there something im doing wrong?
Yotehunter66
Moderator
Yotehunter66
belt issues Empty
PostSubject: Re: belt issues   belt issues Icon_minitimeSat Aug 10, 2013 9:18 pm
Check your weights and make sure you installed them right.
belt issues Empty
PostSubject: Re: belt issues   belt issues Icon_minitimeSat Aug 10, 2013 9:20 pm
Is it seated all the way back.
txgrown1404
txgrown1404
belt issues Empty
PostSubject: Re: belt issues   belt issues Icon_minitimeSat Aug 10, 2013 9:32 pm
anyone have a pic of how the weights go in.  I watched the video james made and I out them in how he did.
teddy is what seated all the way?  the primary
belt issues Empty
PostSubject: Re: belt issues   belt issues Icon_minitimeSat Aug 10, 2013 9:54 pm
Make sure the ribs on the weights are up and towards the center hub,install your cam plate and cover hold everthing tight with your hands.
belt issues Empty
PostSubject: Re: belt issues   belt issues Icon_minitimeSat Aug 10, 2013 10:06 pm
did you get it?
belt issues Empty
PostSubject: Re: belt issues   belt issues Icon_minitimeSat Aug 10, 2013 10:14 pm
yes sorry.
txgrown1404
txgrown1404
belt issues Empty
PostSubject: Re: belt issues   belt issues Icon_minitimeSat Aug 10, 2013 10:33 pm
well I pulled the weights and checked them and they are in right.  when I put the primary on I can see splines showing through the camplate.  I got it to spin clockwise for a bit then I can spin it back counter clockwise but the belt doesn't come all the way to the top.  it fell like im turnin the crank. I have an alternator  and it works off the crank and when I turn the primary it spin my alternator.  feeling lost..   help I wanna ride tomorrow
txgrown1404
txgrown1404
belt issues Empty
PostSubject: Re: belt issues   belt issues Icon_minitimeSat Aug 10, 2013 10:37 pm
my secondary spins freely for to mention that
belt issues Empty
PostSubject: Re: belt issues   belt issues Icon_minitimeSat Aug 10, 2013 11:19 pm
By the way that you worded this, I get that you are spinning the pulleys by hand and expecting the belt to 'variate' (move up and down to change the pulley ratio). The primary has to be spun fast enough to fling the weights outward sufficiently to close the primary sheaves for it to do this. The primary stays fully open up to a bit past idle (more than 1800 RPM before it will move). I don't think anyone is capable of spinning that thing that fast by hand. You will want to have the outer cover off but everything else put together. Run the engine with the machine in neutral. You should be able to see the belt variation as you rev the engine up.
txgrown1404
txgrown1404
belt issues Empty
PostSubject: Re: belt issues   belt issues Icon_minitimeSat Aug 10, 2013 11:28 pm
thanks steve
belt issues Empty
PostSubject: Re: belt issues   belt issues Icon_minitimeSun Aug 11, 2013 9:32 am
new belt??
meats
meats
belt issues Empty
PostSubject: Re: belt issues   belt issues Icon_minitimeSun Aug 11, 2013 9:44 am
when i put mine on i have to spin it counter clockwise, do you have the bolt that spreads the secondary out.
belt issues Empty
PostSubject: Re: belt issues   belt issues Icon_minitimeSun Aug 11, 2013 12:32 pm
pics!!
txgrown1404
txgrown1404
belt issues Empty
PostSubject: Re: belt issues   belt issues Icon_minitimeSun Aug 11, 2013 12:39 pm
I got the belt to ride back up everything looks good.  thanks for all yalls help.
belt issues Empty
PostSubject: Re: belt issues   belt issues Icon_minitimeSun Aug 11, 2013 12:52 pm
cheers
belt issues Empty
PostSubject: Re: belt issues   belt issues Icon_minitimeSun Aug 11, 2013 1:01 pm
what did u find ?
Yotehunter66
Moderator
Yotehunter66
belt issues Empty
PostSubject: Re: belt issues   belt issues Icon_minitimeSun Aug 11, 2013 2:33 pm
Good deal. Beer time!Reneck
txgrown1404
txgrown1404
belt issues Empty
PostSubject: Re: belt issues   belt issues Icon_minitimeSun Aug 11, 2013 8:44 pm
I kept fucking with the shifter and it finally let lose
belt issues Empty
PostSubject: Re: belt issues   belt issues Icon_minitimeSun Aug 11, 2013 8:53 pm
I'm glad you got it worked out.
belt issues Empty
PostSubject: Re: belt issues   belt issues Icon_minitimeSun Aug 11, 2013 9:53 pm
Good for you,did you do you post repair road test?
belt issues Empty
belt issues
» 2011 rhino issues
» Flooding issues
» clutch issues
» Carb issues
» starting issues
