Subject: clutch issues Sun Aug 18, 2013 2:21 pm
slug my wet clutch and installed JBS sheave and I have this pinging noise now and I have checked the weights and they are good. I made a video any help would be nice.
Subject: Re: clutch issues Sun Aug 18, 2013 4:07 pm
cause the cage is not on..it will mess up the one way
txgrown1404
Subject: Re: clutch issues Sun Aug 18, 2013 4:32 pm
it was doing it with the cage on too
txgrown1404
Subject: Re: clutch issues Sun Aug 18, 2013 4:35 pm
took the primary and the fixed sheave off and it didn't do that. kinda sounds like the fixed sheave is catching on something and its has some play where it slides over the splines. dod you think I nedd to replace the fixed sheave
txgrown1404
Subject: Re: clutch issues Tue Aug 20, 2013 7:31 pm
here is what it sounds like with the cage on
Subject: Re: clutch issues Tue Aug 20, 2013 9:48 pm
Probably just the weights rattaling around,when u rev it up it should go away.
txgrown1404
Subject: Re: clutch issues Tue Aug 20, 2013 10:53 pm
it does go away, it there anything I can do to fix it?
Subject: Re: clutch issues Tue Aug 20, 2013 11:55 pm
pak heavily...lol
Subject: Re: clutch issues Wed Aug 21, 2013 5:31 am
i think its the one way
Subject: Re: clutch issues Wed Aug 21, 2013 8:12 am
It should not be noisey, something is worn or broken,it won't go away.
Subject: Re: clutch issues Wed Aug 21, 2013 9:50 am
Check make sure you don't have one weight flipped causing a little slack for that weight. If not, I agree with James on the one way. We had one lock up on us and it sorta made that kinda noise.
txgrown1404
Subject: Re: clutch issues Wed Aug 21, 2013 12:16 pm
i guess james I need you to send me a one way bearing.
Subject: Re: clutch issues Wed Aug 21, 2013 12:22 pm
get pics of camplate and all the rest of the stuff and let me see if i see something
txgrown1404
Subject: Re: clutch issues Wed Aug 21, 2013 12:49 pm
ok will do that when I get off. camplate weights fixed sheave and one way anything else I need to get pics of?
Subject: Re: clutch issues Wed Aug 21, 2013 1:13 pm
both sides of cam plate and different angles..
txgrown1404
Subject: Re: clutch issues Wed Aug 21, 2013 7:47 pm
here are some pics of the camplate
here are a few of the fixed sheave
Subject: Re: clutch issues Thu Aug 22, 2013 8:14 am
camplate is wore in th clip holes
Subject: Re: clutch issues Thu Aug 22, 2013 8:41 am
Good eye!!time to upgrade to a 700 camplate and sliders....
txgrown1404
Subject: Re: clutch issues Thu Aug 22, 2013 11:20 am
hey james can you get a price on 700 camplate, sliders, and a one way bearing
