Who is online? | In total there are 29 users online :: 0 Registered, 0 Hidden and 29 Guests :: 2 Bots None Most users ever online was 207 on Tue Jun 11, 2013 11:13 pm |
| | clutch | |
+3CUSTOMIZEDRHINO13 honda450sfm rhino727 7 posters | Author | Message |
| Subject: clutch Sat Apr 06, 2013 10:26 pm | |
| Well I finished the moter just have to get water pump gasket, an o-ring for intake . So I got started on the clutch that thing was way dirty soaking some parts now , was going to change the spring but don't have socket to fit , just wandering what size that is maybe 45mm, will try to get one tomorrow , well its time for a cold one's | |
| | | honda450sfm
| Subject: Re: clutch Sat Apr 06, 2013 10:30 pm | |
| I had a hard time finding a socket too. Had to get a 45mm socket only it was 3/4 " drive. Haven't gotten around to taking the nut off though. Need to order a bunch of parts from James first. | |
| | | CUSTOMIZEDRHINO13
| Subject: Re: clutch Sat Apr 06, 2013 10:56 pm | |
| We just bought a 1/2 in to 3/4 adapter and it worked great. | |
| | | SteveS
| Subject: Re: clutch Sat Apr 06, 2013 11:31 pm | |
| I am assuming that you are taking about removing the spring that is preloading the secondary sheave? I am imagining everyone is using an impact wrench to get that nut loose while leaning onto it with a spare wheel as a pressing tool. To use an impact wrench, you do indeed need to use a socket wrench. I posted a thread regarding a home-brew compression tool that I made: https://hotrodrhinoforums.forumotion.com/t323-homebrew-secondary-spring-compressorWhen using this tool, the base block is bolted onto the outermost sheave and then held in a vise. In that position it is quite easy to break the nut loose, using a large crescent wrench. DO NOT take the nut off all of the way, else it will all blow up into your face! The sheave is kept from rotating by the base block being clamped onto the vise. Then you need to compress the spring using this tool or the spare wheel technique and simply spin the nut off using your fingers. The order of the steps is reversed when re-assembling and the crescent wrench works then too. | |
| | | madmax 1
| Subject: Re: clutch Sun Apr 07, 2013 9:49 am | |
| nut is 1 13/16 got mine from sears it's 3/4 drive get the 3/4 to 1/2 adapter also | |
| | | rhino727
| Subject: Re: clutch Sun Apr 07, 2013 10:23 am | |
| yea I figured that was it , I have 3/4 drive set but it goes 1 3/4 to 1 7/8 that's called my kind of luck do this shit for a living ( mill wright work) an still run into the not having the one ya need, well off to town | |
| | | rhino727
| Subject: Re: clutch Sun Apr 07, 2013 1:38 pm | |
| back with socket, nut off , this being frist time doing this type of clutch , turning the sheave feels ruff to me how do you separate sheave to service or do you | |
| | | Firefighter
| Subject: Re: clutch Sun Apr 07, 2013 2:08 pm | |
| | | KJrhino
| Subject: Re: clutch Sun Apr 07, 2013 2:59 pm | |
| Great vid its what I used.. pins and seals look em over like James mentions | |
| | | rhino727
| Subject: Re: clutch Sun Apr 07, 2013 6:24 pm | |
| thanks for info the vid is great help nothen like seeing back to garage to finish lookin over secondary thanks again | |
| Subject: Re: clutch | |
| | | | clutch | |
