In total there are 30 users online :: 0 Registered, 0 Hidden and 30 Guests :: 2 Bots
Alignment issue Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Alignment issue Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Alignment issue Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Alignment issue Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Alignment issue Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Alignment issue Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Alignment issue Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Alignment issue Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Alignment issue Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Alignment issue Vote_lcapAlignment issue Voting_barAlignment issue Vote_rcap
 Alignment issue
3 posters
Guenther
Guenther
Alignment issue Empty
PostSubject: Alignment issue   Alignment issue Icon_minitimeSun Jul 07, 2013 1:59 pm
So I was wondering why the hell I had some alignment issues a while back and had come across a few things.
1. I had a bad ball joint that was making matters worse
2. I had a tie rod end that was worn the hell out. Worst case scenario they'll look like this.
Alignment issue 36110
This is what happened during a ride during a Thunderstorm last year.  I ended up bungying them together to limp her home.
3. After replacing items above and still failing to align I found the Issue
Alignment issue Sat_7-11
lol! I don't think your lower A Arms are supposed to look like they from a Grizzly and watch out for rocks.
Also, in checking everything I did notice some of the cotter pins had worn and the nuts were simply loose on good ball joints and tie rod end.  I think James has a video somewhere of here to check for all these loose parts.Dancing Banana
PostSubject: Re: Alignment issue   Alignment issue Icon_minitimeMon Jul 08, 2013 7:17 am
ha ha....time to rebuilt her underside!
PostSubject: Re: Alignment issue   Alignment issue Icon_minitimeMon Jul 08, 2013 9:11 am
that would be it...lol
Alignment issue
» Wheel Alignment Video
» OK, so what could be my issue
» while checking another minor issue...
» 700 Water Pump Issue ... Overheating
