In total there are 21 users online :: 0 Registered, 0 Hidden and 21 Guests :: 3 Bots
OK, so what could be my issue Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
OK, so what could be my issue Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
OK, so what could be my issue Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
OK, so what could be my issue Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
OK, so what could be my issue Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
OK, so what could be my issue Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
OK, so what could be my issue Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
OK, so what could be my issue Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
OK, so what could be my issue Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
OK, so what could be my issue Vote_lcapOK, so what could be my issue Voting_barOK, so what could be my issue Vote_rcap
CamoRhino660
Greeley
rhinopg
Mrs. Hot Rod
theGerg
14 posters
Go to page : 1, 2  Next
theGerg
OK, so what could be my issue Empty
PostSubject: OK, so what could be my issue   OK, so what could be my issue Icon_minitimeWed Mar 20, 2013 9:49 pm
OK, posted this on RF, but lets get it here from the real master. So my ride stops moving on the road on my way back to camp one night. I get towed home...I could hear a tick that got worse before it stopped rolling. Turns out I was 1.25L low on my oil...apparently it spits out oil or something when your riding it hard? Anyway no matter, my bad for not checking the oil...engine never died or stalled, but I just stopped getting forward motion.
Engine has a slap or tick to it now. I have a guy that has pulled the top end of the motor apart. He says its not my valves, and I assume its not my piston? I just got home and need to get some ideas, and I will be talking to him this evening hopefully. So what could it be, something in the bottom end? When I started it up at home, I put it in gear and pushed on the gas with my hand, felt like it wanted to move, but I don't have much room in my garage, and getting it moving wasn't my goal, just wanted to see if the tick stopped after I got some oil splashing around...it didn't.
What is the next step? I gotta pull my motor out? its gonna be a bearing on my crank or something? if I remove the clutch can I get a good look inside the bottom end?
theGerg
PostSubject: Re: OK, so what could be my issue   OK, so what could be my issue Icon_minitimeWed Mar 20, 2013 10:36 pm
update: So my buddy has contacted yamaha, and they basically told him that he doesn't want to go into the bottom end of the motor. They say there are too many finicky parts and that only a pro should do it. He said he took my spark plug out, turned the engine over and it was fine, then he did it again and heard a clunk, did it again and it was fine, did it again and heard a clunk. Does all of this make sense? I trust the guy working on my ride, I don't trust the shops that are telling him he shouldn't do it. They also say that a replacement motor is hard to find and that they have 3 of these rhinos sitting at their shop waiting for new motors. I find this all hard to believe. How tricky is the bottom end...guess Im in some hot water here with my ride...if I gotta replace something in the bottom, is there an upgrade I should be putting in?
theGerg
PostSubject: Re: OK, so what could be my issue   OK, so what could be my issue Icon_minitimeWed Mar 20, 2013 10:53 pm
they also told him that these motors are notorious for this...more truth or mistruth?
PostSubject: Re: OK, so what could be my issue   OK, so what could be my issue Icon_minitimeThu Mar 21, 2013 1:28 am
Sounds like rod and/or main bearing problems. I don't know what to tell you. If you find that you need a new rod or crank, don't replace it with factory parts, upgrade to something better. Once you figure out what all you need, call JBS.
theGerg
PostSubject: Re: OK, so what could be my issue   OK, so what could be my issue Icon_minitimeThu Mar 21, 2013 2:21 am
the big question is, is it something that a mechanic can do, or should I leave it to the ATV pro's?
PostSubject: Re: OK, so what could be my issue   OK, so what could be my issue Icon_minitimeThu Mar 21, 2013 7:49 am
I say if the guy knows engines then go for it. But i dont know the skill level of the guy you are talking about so i cant make that call.
PostSubject: Re: OK, so what could be my issue   OK, so what could be my issue Icon_minitimeThu Mar 21, 2013 8:58 am
The rhino engine is a piece of cake if you have been working on them for awhile, Not for the first timer.
Mrs. Hot Rod
Mrs. Hot Rod
PostSubject: Re: OK, so what could be my issue   OK, so what could be my issue Icon_minitimeThu Mar 21, 2013 9:47 am
seen alot of them with the bolts in the middle drive that have come loose
rhinopg
PostSubject: Re: OK, so what could be my issue   OK, so what could be my issue Icon_minitimeThu Mar 21, 2013 11:46 am
Thats what happened to my engine,Yamaha dealer told me that the motor wasnt worth tearing down to see what was wrong.They wanted to sell me a new engine for 6000.oo dollars plus a 1000.oo to re and re it.Then there is taxes on top of that.Then there is also probley other hidden costs that they will come up with on the way.I torn the engine down my self and its tottaly rebuildable,so i might as well ad some horse power to it likeChrisH is doing.If you can take it apart with your friend and see whats wrong with the engine it might not be that hard to do as you think.There is no shortage of guys on this site that are willing to help with any questions.Good luck
Greeley
Greeley
PostSubject: Re: OK, so what could be my issue   OK, so what could be my issue Icon_minitimeThu Mar 21, 2013 2:13 pm
Strip it down, it's screwed up already so you might as well give it a shot and learn along the way. As you encounter roadblocks just ask and post pictures, the people on this site will guide you along.
theGerg
PostSubject: Re: OK, so what could be my issue   OK, so what could be my issue Icon_minitimeFri Mar 22, 2013 12:04 am
ok, we are gonna giver...so are there any upgrades I might as well do since Im going into my bottom end? I gotta pull the entire motor to do this?
CamoRhino660
CamoRhino660
PostSubject: Re: OK, so what could be my issue   OK, so what could be my issue Icon_minitimeFri Mar 22, 2013 6:48 am
Yes you gotta pull it out. Good rod and piston,and middle drive support.
PostSubject: Re: OK, so what could be my issue   OK, so what could be my issue Icon_minitimeMon Mar 25, 2013 8:59 pm
dido on camorhino660
while your in there stroker? maybe bore ? 10/1 11/1?
PostSubject: Re: OK, so what could be my issue   OK, so what could be my issue Icon_minitimeMon Mar 25, 2013 9:58 pm
X3, All good area's to upgrade.
PostSubject: Re: OK, so what could be my issue   OK, so what could be my issue Icon_minitimeMon Mar 25, 2013 10:52 pm
i love strokers...
theGerg
PostSubject: Re: OK, so what could be my issue   OK, so what could be my issue Icon_minitimeTue Mar 26, 2013 12:44 am
ok, whats a stroker?
And my other question is...how do I get the drive shafts out? Do I gotta pull the entire rear end out to get the motor out?
CamoRhino660
CamoRhino660
PostSubject: Re: OK, so what could be my issue   OK, so what could be my issue Icon_minitimeTue Mar 26, 2013 5:38 am
Just unbolt front or rear and move it just enough to get one to slid out. Then the motor comes out pretty easy.
PostSubject: Re: OK, so what could be my issue   OK, so what could be my issue Icon_minitimeTue Mar 26, 2013 9:31 am
we always loosen the front one
meats
meats
PostSubject: Re: OK, so what could be my issue   OK, so what could be my issue Icon_minitimeTue Mar 26, 2013 6:47 pm
yep it sounds like what happen to mine after i bought it but i was two quarts low. but the dealer went good for it but they had to put all new from da crank up to even a new head and it wasnt really knocking that bad i was just glad they went good for it. i would get a syphon break for it to make sure you dont lose your oil after rebuild
theGerg
PostSubject: Re: OK, so what could be my issue   OK, so what could be my issue Icon_minitimeTue Mar 26, 2013 10:39 pm
whats a syphon break, where would I get one?
Mrs. Hot Rod
Mrs. Hot Rod
PostSubject: Re: OK, so what could be my issue   OK, so what could be my issue Icon_minitimeTue Mar 26, 2013 10:59 pm
We have them .... $18 for the siphon break, we also have the little filters for $10 ... shipping would be $6. Here is a vid that explains a little about how it works ....
https://www.youtube.com/watch?v=K0xNadFTfZM&feature=youtu.be
Deuces wild
Deuces wild
PostSubject: Re: OK, so what could be my issue   OK, so what could be my issue Icon_minitimeTue Mar 26, 2013 11:40 pm
Do I need a siphon break on a 660 with a cdi box? Or is it just the 700?
PostSubject: Re: OK, so what could be my issue   OK, so what could be my issue Icon_minitimeWed Mar 27, 2013 12:18 am
the more the rings are wore the more oil they wanna push and high rpms alot does it...660 or 700
Deuces wild
Deuces wild
PostSubject: Re: OK, so what could be my issue   OK, so what could be my issue Icon_minitimeWed Mar 27, 2013 12:21 am
My 07 only has 350 miles on it do you think I need one? I have not bought anything YET I'm just trying to get together a grocery list.
PostSubject: Re: OK, so what could be my issue   OK, so what could be my issue Icon_minitimeWed Mar 27, 2013 12:32 am
if you plan on running it hard do it
» Alignment issue
» while checking another minor issue...
» 700 Water Pump Issue ... Overheating
