| OK, so what could be my issue | |
+10WV Hot Rod Rhino rhino727 CamoRhino660 Greeley rhinopg Mrs. Hot Rod Stuntmanmike chuddly Hump theGerg 14 posters |
meats
| Subject: Re: OK, so what could be my issue Wed Mar 27, 2013 8:08 pm | |
| i would say get one for the price james has them for. its alot cheaper than paying to do a rebuild. | |
| Subject: Re: OK, so what could be my issue Fri Mar 29, 2013 3:02 pm | |
| back to whats a stroker= go faster an the over size bore= theres no replacement for displacement billet middle gear support=saving your bottom end when pot metal stock one exsplodes making for a very exspensive rebuild:pale | |
| Subject: Re: OK, so what could be my issue Fri Mar 29, 2013 9:59 pm | |
theGerg
| Subject: Re: OK, so what could be my issue Sat Mar 30, 2013 7:48 pm | |
| Subject: Re: OK, so what could be my issue Sat Mar 30, 2013 7:50 pm | |
| Yes He does ! Dynateck, I think | |
theGerg
| Subject: Re: OK, so what could be my issue Sun Apr 07, 2013 1:07 pm | |
| so I heard that the rhino sometimes can skip a tooth on the timing chain...is this true? MY mechanic friend has had my ride for 2 weeks now and hes not putting much time on it...he came to me with this idea, he has the motor pulled, but hasn't torn it down yet...he figured it could be a timing issue rather than a spun bearing | |
theGerg
| Subject: Re: OK, so what could be my issue Sun Apr 07, 2013 5:58 pm | |
| the bearing on one of my pistons is shot...but my mechanic is afraid to crack the block open. He says he needs a special tool or something? Does this make sense? | |
Briki
Posts : 68 Join date : 2013-03-11 Age : 47
| Subject: Re: OK, so what could be my issue Sat Apr 13, 2013 1:38 pm | |
| - WV Hot Rod Rhino wrote:
- if you plan on running it hard do it
Hi James, I need this kit: 1- siphon break. 2- the small filter. 3- that rubber plug to close breathing hose inlet in intake box. shpped to: 44236 OH PM sent Thanks | |
theGerg
| Subject: Re: OK, so what could be my issue Sun Jun 02, 2013 12:15 pm | |
| So the problem was a spun bearing on the main shaft...2k later and Im ready to go again... | |
| Subject: Re: OK, so what could be my issue Mon Jun 03, 2013 7:05 am | |
| It sucks to spend the money on it...but glad you are up and running again. | |
| Subject: Re: OK, so what could be my issue | |
