In total there are 32 users online :: 0 Registered, 0 Hidden and 32 Guests :: 3 Bots
pulling out 700 engine Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
pulling out 700 engine Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
pulling out 700 engine Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
pulling out 700 engine Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
pulling out 700 engine Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
pulling out 700 engine Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
pulling out 700 engine Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
pulling out 700 engine Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
pulling out 700 engine Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
pulling out 700 engine Vote_lcappulling out 700 engine Voting_barpulling out 700 engine Vote_rcap
2 posters
rhinopg
pulling out 700 engine Empty
PostSubject: pulling out 700 engine   pulling out 700 engine Icon_minitimeMon Mar 11, 2013 10:41 pm
I have the motor just about ready to come out.Need some help, how do i disconect the front and rear drive shaft from the engine so i can pull the motor out.do i have to unbolt and drill out the rivets on the floor to get that huge air box out of the way or just undo the hose clamp under the hood and a couple of screws then would i have enough play to move the air box to the side. I have a engine hoist is that what you guys use to lift out engine.Any ideas would be apprecieted,Thanks.
PostSubject: Re: pulling out 700 engine   pulling out 700 engine Icon_minitimeMon Mar 11, 2013 11:04 pm
unbolt the front diff and pull forward....undo the clamp under the hood...i lift them out by hand....
rhinopg
PostSubject: Re: pulling out 700 engine   pulling out 700 engine Icon_minitimeMon Mar 11, 2013 11:43 pm
Thankyou James,When i get the engine torn down i will give you a call i willbe needing some parts and info.
rhinopg
PostSubject: Re: pulling out 700 engine   pulling out 700 engine Icon_minitimeTue Mar 12, 2013 9:31 pm
Thankyou James for your help today,I had to use just about a whole can of wd- 40 got the bolt to move but didnt have enough room to really tourque on the bolt,so i took off the belly pan and then i could use a long ratchet to get some leverage,finnally got the bolt out.motor is sitting on the bench now,i will tear it down this sunday and see what the damage is.
» side engine fan
» tips on pulling motor from a 660
» Win a FREE JBS 700 Sheave!
» Engine case?
» Engine sputter
