In total there are 59 users online :: 0 Registered, 0 Hidden and 59 Guests :: 1 Bot
tips on pulling motor from a 660  Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
tips on pulling motor from a 660  Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
tips on pulling motor from a 660  Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
tips on pulling motor from a 660  Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
tips on pulling motor from a 660  Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
tips on pulling motor from a 660  Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
tips on pulling motor from a 660  Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
tips on pulling motor from a 660  Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
tips on pulling motor from a 660  Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
tips on pulling motor from a 660  Vote_lcaptips on pulling motor from a 660  Voting_bartips on pulling motor from a 660  Vote_rcap
5 posters
tips on pulling motor from a 660  Empty
PostSubject: tips on pulling motor from a 660    tips on pulling motor from a 660  Icon_minitimeSun Nov 24, 2013 2:52 am
im going to be pulling the motor out of my rhino tonight looking for a few tips mostly on how to remove driveshafts do I need to pull the diffs to get the shafts off the motor? an any other tips that will make it go smooth. thanks guys
CamoRhino660
CamoRhino660
PostSubject: Re: tips on pulling motor from a 660    tips on pulling motor from a 660  Icon_minitimeSun Nov 24, 2013 7:58 am
It is for sure easier if you drop the bolts in the front diff and move it forward enough to get the driveshaft out.
PostSubject: Re: tips on pulling motor from a 660    tips on pulling motor from a 660  Icon_minitimeSun Nov 24, 2013 8:01 pm
when I did mine didn't ask an ended up taking back diff/axles out , then read about moving front to get drive shaft out  live an learn  also I took motor loose from mount believe taking mount loose from frame would be faster/easier, one more thing freezer bags made to write on , as u break down u can put bolts from each section an label helps keeping things in write place going back together, good luck
PostSubject: Re: tips on pulling motor from a 660    tips on pulling motor from a 660  Icon_minitimeSun Nov 24, 2013 8:13 pm
Good tips,systematic approach,keeps stuff in the right place the bolts especially.
PostSubject: Re: tips on pulling motor from a 660    tips on pulling motor from a 660  Icon_minitimeMon Nov 25, 2013 9:35 am
10-4 thanks for the tips guys going to pull it off today an get it to the shop.
brewis
brewis
PostSubject: Re: tips on pulling motor from a 660    tips on pulling motor from a 660  Icon_minitimeMon Nov 25, 2013 1:54 pm
I found this, hope it helps a little and let us know how it goes.  I'll be doing the same soon.
 http://www.rhinoforums.net/engine/68719-how-pull-660-engine-101-a.html?highlight=pull+engine
PostSubject: Re: tips on pulling motor from a 660    tips on pulling motor from a 660  Icon_minitimeMon Nov 25, 2013 6:28 pm
well got it pulled out.. not a bad job at all think the worse part is getting to the front diff bolts to drop it down other than that its a fairly easy job.. think i may have a problem with my primary sheave when i pulled it apart most of the grease was all thru the clutch cover and all over the support cage. anyone know why the grease came out of the clutch? oring was in place as where all the little screws that hold the cover on the clutch and its yamalube clutch grease.
PostSubject: Re: tips on pulling motor from a 660    tips on pulling motor from a 660  Icon_minitimeMon Nov 25, 2013 7:16 pm
Maybe there was a little to much grease?
PostSubject: Re: tips on pulling motor from a 660    tips on pulling motor from a 660  Icon_minitimeMon Nov 25, 2013 7:24 pm
that could be i thought i used about the same amout as i did when i first installed the jbs sheave an when i pulled it 500 miles later to service it it was fine but this time grease was everywhere
PostSubject: Re: tips on pulling motor from a 660    tips on pulling motor from a 660  Icon_minitimeMon Nov 25, 2013 7:26 pm
I just hope it was just something as harmless as a little extra grease,you didn't mention any performance issues.
» pulling out 700 engine
» rhino not pulling it self
» Win a FREE JBS 700 Sheave!
» 07 660 motor parts
» 660 motor build questions
