In total there are 23 users online :: 0 Registered, 0 Hidden and 23 Guests :: 2 Bots
rhino not pulling it self Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
rhino not pulling it self Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
rhino not pulling it self Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
rhino not pulling it self Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
rhino not pulling it self Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
rhino not pulling it self Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
rhino not pulling it self Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
rhino not pulling it self Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
rhino not pulling it self Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
rhino not pulling it self Vote_lcaprhino not pulling it self Voting_barrhino not pulling it self Vote_rcap
Rootin'Rhino
jaydog13
10 posters
Go to page : 1, 2  Next
jaydog13
rhino not pulling it self Empty
PostSubject: rhino not pulling it self   rhino not pulling it self Icon_minitimeSat Apr 06, 2013 6:49 pm
about 2 mounths ago i was riding and the rhino it started feeling like the wet
clutch was slipping or it had a really high stall spring . so then i decided ill
put a new wet clutch a jbs sheave belt one way bearing ...... i got all this
back together just yesturday (2 mounths) since the last ride. i started the
bike, started no prob. i went to ride down the drive and it still had the same
really high stall spring feelig so i turned around so go back and it wouldnt
pull itself. it would rock about 1/4 turn foward then not enogh power same in
reverse. i tired 4wd and it still would pull itself . the front tires still roll
free. i jack up the ass end to turn the wheels by hand and i cant turn them if i
rock it back and forth pretty hard ill get it to finally break loose for about
1/2 turn ?????? HELP PLEASE
PostSubject: Re: rhino not pulling it self   rhino not pulling it self Icon_minitimeSat Apr 06, 2013 9:57 pm
could it be in the rear end or back brake ? did u have in neutral when u was rockin
jaydog13
PostSubject: Re: rhino not pulling it self   rhino not pulling it self Icon_minitimeSat Apr 06, 2013 10:44 pm
it was in neutral for sure . and its not in the brakes either im thinking its in the rear end .i was just trying to get a few troubleshooting hints
PostSubject: Re: rhino not pulling it self   rhino not pulling it self Icon_minitimeSat Apr 06, 2013 11:00 pm
Check the diff. fluid maybe?
jaydog13
PostSubject: Re: rhino not pulling it self   rhino not pulling it self Icon_minitimeSat Apr 06, 2013 11:40 pm
i checked the fluid its full.
PostSubject: Re: rhino not pulling it self   rhino not pulling it self Icon_minitimeSun Apr 07, 2013 1:09 am
Drain some out and see what you have for debris or chunks..
PostSubject: Re: rhino not pulling it self   rhino not pulling it self Icon_minitimeSun Apr 07, 2013 8:24 am
what oil you running
Rootin'Rhino
Rootin'Rhino
PostSubject: Re: rhino not pulling it self   rhino not pulling it self Icon_minitimeSun Apr 07, 2013 9:22 am
If it was in the rear end it would just pull/bogg the engine down right?
jaydog13
PostSubject: Re: rhino not pulling it self   rhino not pulling it self Icon_minitimeSun Apr 07, 2013 12:26 pm
i run maxima oil it it 10-30 . the engine is not bogging all the way down it will still rev it just wont move . and like i said i jacked the rear end up and i cant move the tires.
PostSubject: Re: rhino not pulling it self   rhino not pulling it self Icon_minitimeSun Apr 07, 2013 12:48 pm
brakes or rear end....take the caliper off and see what it does
jaydog13
PostSubject: Re: rhino not pulling it self   rhino not pulling it self Icon_minitimeSun Apr 07, 2013 12:52 pm
ok will do asap and get back to u guys thanks. what would it be in the rear end
PostSubject: Re: rhino not pulling it self   rhino not pulling it self Icon_minitimeSun Apr 07, 2013 1:30 pm
x2 on the brakes , the diff. would be bearings an or ring an pinon not much more in there
PostSubject: Re: rhino not pulling it self   rhino not pulling it self Icon_minitimeSun Apr 07, 2013 3:08 pm
Hopefully the brakes.. good luck
DEZLFREK
PostSubject: Re: rhino not pulling it self   rhino not pulling it self Icon_minitimeSun Apr 07, 2013 4:00 pm
i think your wet clutch is toast..
PostSubject: Re: rhino not pulling it self   rhino not pulling it self Icon_minitimeSun Apr 07, 2013 5:03 pm
Is the Maxima oil you are using JASO-MA (wet clutch compliant)?
jaydog13
PostSubject: Re: rhino not pulling it self   rhino not pulling it self Icon_minitimeSun Apr 07, 2013 8:38 pm
it has a brand new wet clutch from james. and yes the maxima is jaso-ma app.
i check the brakes and still no go. so what should or how should i go about messing with the rear end.
PostSubject: Re: rhino not pulling it self   rhino not pulling it self Icon_minitimeSun Apr 07, 2013 9:53 pm
so you sure the brakes are free? then its diff pull axles then brake caliber then undo mount bolts an pull the diff , I would check the drive shaft after you got diff loss see if it turns , thought how did you check the brakes were ok? I would make sure the brakes are good before pulling the diff pretty good job on the ring &pinon set-up not mention the cost, good luck
jaydog13
PostSubject: Re: rhino not pulling it self   rhino not pulling it self Icon_minitimeMon Apr 08, 2013 7:56 pm
UPDATE: yesturday i pull the brake caliper off just to make sure. so that wasnt the problem . Today i pulled the two diff bolts out slid the diff back,pulled the drive shaft out from the diff side , tires still did not spend . and yes in neutral the drice shaft would spend and in gear it would not. so the proble is in the rear diff . now tomorrow i will pull the diff out and fix that i guess. ill keep updating to the next step and what has gone wrong. im hoping a froze bearing.
PostSubject: Re: rhino not pulling it self   rhino not pulling it self Icon_minitimeWed Apr 10, 2013 6:56 pm
I was thinking today , maybe wheel bearing would know as soon as you pull axles out an check the diff again Question
jaydog13
PostSubject: Re: rhino not pulling it self   rhino not pulling it self Icon_minitimeWed Apr 10, 2013 10:06 pm
well well it was the wheel bearing.
PostSubject: Re: rhino not pulling it self   rhino not pulling it self Icon_minitimeWed Apr 10, 2013 11:40 pm
Good find...
PostSubject: Re: rhino not pulling it self   rhino not pulling it self Icon_minitimeThu Apr 11, 2013 6:15 pm
glad it was not the diff lol!
PostSubject: Re: rhino not pulling it self   rhino not pulling it self Icon_minitimeThu Apr 11, 2013 6:31 pm
nice!!
PostSubject: Re: rhino not pulling it self   rhino not pulling it self Icon_minitimeThu Apr 11, 2013 7:35 pm
great news alot cheaper fix
PostSubject: Re: rhino not pulling it self   rhino not pulling it self Icon_minitimeThu Apr 11, 2013 10:56 pm
Glad it worked out!!!
» Win a FREE JBS 700 Sheave!
» pulling out 700 engine
» tips on pulling motor from a 660
» Rhino from Ky
» My 09 Rhino
