| Sway Bar Disconnect | |
+13REDRHINO64 Dizzledog1 Kenny G madmax 1 ChrisH KJrhino skeeter9 Hump tjt603 southark WV Hot Rod Rhino Firefighter Yotehunter66 17 posters |
Yotehunter66 Moderator
| Subject: Sway Bar Disconnect Tue Mar 12, 2013 8:40 am | |
| I have not unhooked the sway bar on my 450 yet. How many of you have and what do you think? | |
| Subject: Re: Sway Bar Disconnect Tue Mar 12, 2013 11:52 am | |
| I've kept mine hooked up . Reason being, I like to slide around some corners and it keeps the back end a little flatter. I think You would gain some flex by taking it off. Just not an advantage for me. | |
| Subject: Re: Sway Bar Disconnect Tue Mar 12, 2013 12:15 pm | |
| i like running a front one without the rear in rough and both in fast trails | |
southark
| Subject: Re: Sway Bar Disconnect Tue Mar 12, 2013 12:30 pm | |
| I don't run one on mine but I'm riding pretty slow and in the mud a lot and it gives me more flex to crawl around down in the ruts. | |
tjt603
| Subject: Re: Sway Bar Disconnect Tue Mar 12, 2013 12:32 pm | |
| i do alot of trail and mud riding so i took mine off its alot better for me i love it. And you can still go fast in it you just cant take a turn doing 40mph which i dont plan on doing anyway. | |
| Subject: Re: Sway Bar Disconnect Tue Mar 12, 2013 12:48 pm | |
| HAHA Sounds like I need to un hook my mine for a weekend ! | |
| Subject: Re: Sway Bar Disconnect Tue Mar 12, 2013 2:21 pm | |
| If you have wheel spacers on the back, or wider wheels, you will be ok in the turns. It will be a little scary at 1st, but you will get used to it. I took it off the 450 I used to have, and it rode alot smoother and didn't lean near as much in the off camber stuff. | |
| Subject: Re: Sway Bar Disconnect Tue Mar 12, 2013 2:26 pm | |
| Got a 2 day ride this weekend so I'm going to disconnect and just strap it up. See what happens. Thanks Hump ! | |
| Subject: Re: Sway Bar Disconnect Tue Mar 12, 2013 2:33 pm | |
| - Firefighter wrote:
- Got a 2 day ride this weekend so I'm going to disconnect and just strap it up. See what happens. Thanks Hump !
Even with wider wheels or spacers, you may want to adjust you shocks up a little. | |
| Subject: Re: Sway Bar Disconnect Tue Mar 12, 2013 2:39 pm | |
| Good thinkin. I meant to add a little more spring adjustment anyway. Stiffen up the back a little. I did crawl up a waterfall last weekend and would have been nice to have had a touch more flex. | |
skeeter9
Posts : 171 Join date : 2013-03-10 Age : 39 Location : kommifornia
| Subject: Re: Sway Bar Disconnect Tue Mar 12, 2013 3:23 pm | |
| I'm installing my mid travel and pulled it off so we shall see what she rides like when I get it finished let us know firefighter | |
| Subject: Re: Sway Bar Disconnect Tue Mar 12, 2013 6:53 pm | |
| - WV Hot Rod Rhino wrote:
- i like running a front one without the rear in rough and both in fast trails
So your hooking and unhooking depending on where your going to ride for the weekend? | |
| Subject: Re: Sway Bar Disconnect Tue Mar 12, 2013 6:58 pm | |
| - Hump wrote:
- If you have wheel spacers on the back, or wider wheels, you will be ok in the turns. It will be a little scary at 1st, but you will get used to it. I took it off the 450 I used to have, and it rode alot smoother and didn't lean near as much in the off camber stuff.
I thought they didn't even put them on them anymore. Part of the recall was to remove it wasn't it? I don't even know if mine has the spacers, which was part of the recall too I think. Do the bearings wear faster with the wheel spacers? | |
| Subject: Re: Sway Bar Disconnect Tue Mar 12, 2013 7:10 pm | |
| it is...if the recall was done it should have....a little | |
| Subject: Re: Sway Bar Disconnect Tue Mar 12, 2013 7:27 pm | |
| Huh? I will have to get the serial number off mine and check with the dealer and see if it was ever done. | |
| Subject: Re: Sway Bar Disconnect Tue Mar 12, 2013 11:57 pm | |
| can some one explain the recall a bit I've had my rhino a while but tore it down to get rid of the bronco clutch when i bought it. sport edition if it makes a difference. | |
| Subject: Re: Sway Bar Disconnect Wed Mar 13, 2013 12:10 am | |
| If I understand right, It was a voluntary "fix" by Yamaha. You get rear wheel spacers, factory half doors and they remove rear sway bar. | |
| Subject: Re: Sway Bar Disconnect Wed Mar 13, 2013 2:14 am | |
- If I understand right, It was a voluntary "fix" by Yamaha. You get rear wheel spacers, factory half doors and they remove rear sway bar.
That's right. | |
| Subject: Re: Sway Bar Disconnect Wed Mar 13, 2013 2:19 am | |
| My 2011 Rhino did not come with a sway bar, neither did the 2012 and the 2013 in our group. I love the articulation for the mud and ruts. | |
| Subject: Re: Sway Bar Disconnect Wed Mar 13, 2013 2:20 am | |
| - Yotehunter66 wrote:
I thought they didn't even put them on them anymore. Part of the recall was to remove it wasn't it? I don't even know if mine has the spacers, which was part of the recall too I think. Do the bearings wear faster with the wheel spacers? Sorry for confusing you. I took it off my 08 450. It had it and no spacers. My 2012 doesn't have one, and it has wheel spacers from the factory. Seems like the spacers would put more load on the bearings. I really like how my sport handles with the rear being just a little wider than the front. It corners great. | |
| Subject: Re: Sway Bar Disconnect Wed Mar 13, 2013 6:57 am | |
| I'm just wondering if mine hasn't been done if Yamaha will still do it. Mine has the half-doors but the sway bar is still there. I don't recall if I had spacers or not. I'll have to look. | |
| Subject: Re: Sway Bar Disconnect Wed Mar 13, 2013 9:47 am | |
So your hooking and unhooking depending on where your going to ride for the weekend? ...yep...ride it mostly with the rear unhooked for comfort...faster with it hooked though | |
| Subject: Re: Sway Bar Disconnect Wed Mar 13, 2013 7:22 pm | |
| mine is off like the better articulation without it | |
| Subject: Re: Sway Bar Disconnect Wed Mar 13, 2013 10:09 pm | |
| hmm Ill have to look and see if mine is there it already had half doors? and aftermarket wheel spacers thanks guys.. | |
| Subject: Re: Sway Bar Disconnect Thu Mar 14, 2013 1:50 pm | |
| Yamaha should through in a saddle horn for the passanger side next to the air box also. Anyone lookin for a sway bar, I've got one you can have. It's your - pay shipping | |
| Subject: Re: Sway Bar Disconnect | |
