| Sway Bar Disconnect | |
+13REDRHINO64 Dizzledog1 Kenny G madmax 1 ChrisH KJrhino skeeter9 Hump tjt603 southark WV Hot Rod Rhino Firefighter Yotehunter66 17 posters |
Dizzledog1
| Subject: Re: Sway Bar Disconnect Mon Mar 18, 2013 6:12 pm | |
| How much do I need to stiffen up the rear shocks when I take off sway bar. I have special edition with the piggy back shocks. Quarter turn? More? Less? | |
| Subject: Re: Sway Bar Disconnect Mon Mar 18, 2013 7:05 pm | |
| I disconnected my sway bar also,rides alot better over the rocky trails...doesent seem to jerk you around as much!! love it | |
sneaky snake
Posts : 14 Join date : 2013-03-10 Age : 75 Location : New Haven,WV
| Subject: Re: Sway Bar Disconnect Mon Mar 18, 2013 7:19 pm | |
| I ride with mone hooked up some days and unhooked some times, all has to do with how and where i ride | |
Yotehunter66 Moderator
| Subject: Re: Sway Bar Disconnect Fri Mar 22, 2013 8:39 pm | |
| Is this what I want to unhook? | |
| Subject: Re: Sway Bar Disconnect Fri Mar 22, 2013 8:50 pm | |
| Yes,just take the nut loose from the a-arm and zip tie the bar up out of the way. | |
| Subject: Re: Sway Bar Disconnect Fri Mar 22, 2013 8:52 pm | |
| Then if you like the way it rides,you can take the bar completely off. | |
| Subject: Re: Sway Bar Disconnect Fri Mar 22, 2013 10:11 pm | |
| Okay. Just wanted to make sure I didn't unhook the wrong thing. Thanks. | |
| Subject: Re: Sway Bar Disconnect Sat Mar 23, 2013 12:55 pm | |
| How many of you had to cut yours off? | |
Lucky7
Posts : 8 Join date : 2013-03-23 Age : 44 Location : Traverse City MI
| Subject: Re: Sway Bar Disconnect Sat Mar 23, 2013 9:07 pm | |
| I just unhooked mine the other day and I like it so far. | |
| Subject: Re: Sway Bar Disconnect Sat Mar 23, 2013 9:11 pm | |
| I just unbolted mine and took it off. | |
| Subject: Re: Sway Bar Disconnect Sat Mar 23, 2013 10:15 pm | |
| I've sprayed them down but so far no luck. Maybe if I take off my a-arm guards I can use my impact. | |
skeeter9
Posts : 171 Join date : 2013-03-10 Age : 39 Location : kommifornia
| Subject: Re: Sway Bar Disconnect Fri Apr 05, 2013 1:30 am | |
| Mine came off pretty easy although once nut got to a certain point whole piece would spin so I held the threaded part with pliers and was able to get nut rest of way off | |
| Subject: Re: Sway Bar Disconnect Fri Apr 05, 2013 2:03 am | |
| - Yotehunter66 wrote:
- I've sprayed them down but so far no luck. Maybe if I take off my a-arm guards I can use my impact.
Put it all back together and take it to the dealer get the doors and wheel spacers and let them deal with it. | |
LouisianaRebel
Posts : 66 Join date : 2013-03-10
| Subject: Re: Sway Bar Disconnect Fri Apr 05, 2013 12:33 pm | |
| Do the a arms drop farther if it is off? My cv is close to hitting sometimes with lift so i don't want it to be worse without swaybar. | |
| Subject: Re: Sway Bar Disconnect | |
