In total there are 35 users online :: 0 Registered, 0 Hidden and 35 Guests :: 1 Bot
middle drive gear Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
middle drive gear Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
middle drive gear Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
middle drive gear Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
middle drive gear Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
middle drive gear Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
middle drive gear Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
middle drive gear Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
middle drive gear Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
middle drive gear Vote_lcapmiddle drive gear Voting_barmiddle drive gear Vote_rcap
 middle drive gear
3 posters
mr sandman
mr sandman
middle drive gear Empty
PostSubject: middle drive gear   middle drive gear Icon_minitimeFri Sep 13, 2013 12:51 pm
just curious as to what the middle drive gear or middle drive support actually is. ive never been into the bottom end of my rhino. just wanted to get a little more insight on the weak link.
PostSubject: Re: middle drive gear   middle drive gear Icon_minitimeSun Sep 15, 2013 7:57 am
the middle drive support is a weak link , if you ever open up the case's that is a must upgrade. the middle drive gear is sending power to the through shaft which the front an back drive shafts hook too . the middle support will bust under the load , the oem is pot aluminum just a bad set-up replace with a billet piece no more worries of braking . also when one lets go it can take out most of the trans gears , through shaft & gears , middle drive gear , bust the case maybe even the crank, very $$$$$ repair
mr sandman
mr sandman
PostSubject: Re: middle drive gear   middle drive gear Icon_minitimeMon Sep 16, 2013 11:27 am
wow definately would be a costly repair. ive heard about it before just never actually known what it was. thanks for the insite. is this a problem for both the 660 and 700??
PostSubject: Re: middle drive gear   middle drive gear Icon_minitimeMon Sep 16, 2013 11:58 am
Yes I believe it is if you do it do the reverse gear upgrade also.
middle drive gear
» Reverse gear upgrade
» 09 700 ring gear and pinion
» help adjusting the gear select shifter
» 2009 700 rhino wont start in gear
» middle drive support
