| Reverse gear upgrade | |
+1208Rhino450SE CamoRhino660 RADICAL RAM T.Rhino weekendwarriorfsw32 bhawk southark tjt603 WV Hot Rod Rhino Firefighter LouisianaRebel Quadog 16 posters |
Quadog
| Subject: Reverse gear upgrade Mon Mar 11, 2013 8:31 am | |
| I need to get a reverse upgrade kit for my 08 700. How much? Where at? Best place? I guess I need a complete gasket kit too?
Quadog
| Subject: Re: Reverse gear upgrade Mon Mar 11, 2013 1:43 pm | |
| Just talked to James. He hooked me up with everything I need. Gaskets & all. Gonna be a big job. I will takes pics & post my progress. Wish me luck. | |
LouisianaRebel
Posts : 66 Join date : 2013-03-10
| Subject: Re: Reverse gear upgrade Mon Mar 11, 2013 1:48 pm | |
| reverse upgrade? What does that do? | |
| Subject: Re: Reverse gear upgrade Mon Mar 11, 2013 1:49 pm | |
| Ask Southark, He do it last week. | |
| Subject: Re: Reverse gear upgrade Mon Mar 11, 2013 2:36 pm | |
| Subject: Re: Reverse gear upgrade Mon Mar 11, 2013 2:41 pm | |
| - LouisianaRebel wrote:
- reverse upgrade? What does that do?
they are known for the snap ring popping out of the groove and let the gear slide down and you loose reverse...this one eliminates the clip.. | |
LouisianaRebel
| Subject: Re: Reverse gear upgrade Mon Mar 11, 2013 3:13 pm | |
| Great more stuff to add. | |
tjt603
| Subject: Re: Reverse gear upgrade Mon Mar 11, 2013 3:36 pm | |
| ^^^^ I was thinking the same thing ^^^^^^^ | |
Quadog
| Subject: Re: Reverse gear upgrade Mon Mar 11, 2013 4:04 pm | |
| Bad part is engine removal and splitting the cases just to fix it. Big bucks at dealer. | |
LouisianaRebel
| Subject: Re: Reverse gear upgrade Mon Mar 11, 2013 4:16 pm | |
| - Quadog wrote:
- Bad part is engine removal and splitting the cases just to fix it. Big bucks at dealer.
How does this install? | |
Quadog
| Subject: Re: Reverse gear upgrade Mon Mar 11, 2013 4:20 pm | |
| Just replace the one thats there already. Piece o cake. NOT Gotta split cases | |
LouisianaRebel
| Subject: Re: Reverse gear upgrade Mon Mar 11, 2013 5:32 pm | |
| well fk. Ill wait until it decides to quit. haha | |
Quadog
| Subject: Re: Reverse gear upgrade Tue Mar 12, 2013 7:55 am | |
| Don't fix it if it ain't broke! Yours may never need this. | |
| Subject: Re: Reverse gear upgrade Tue Mar 12, 2013 8:39 am | |
| cases have to be split.... | |
southark
| Subject: Re: Reverse gear upgrade Wed Mar 13, 2013 8:41 pm | |
| Subject: Re: Reverse gear upgrade Wed Mar 13, 2013 8:53 pm | |
bhawk
Posts : 15 Join date : 2013-03-11 Location : Watkins, Colorado
| Subject: Re: Reverse gear upgrade Wed Mar 13, 2013 11:33 pm | |
| I'm bout to do mine when i can find 12-14 hours. | |
| Subject: Re: Reverse gear upgrade Wed Mar 13, 2013 11:40 pm | |
| For once I'm glad I own a 660
Quadog
| Subject: Re: Reverse gear upgrade Thu Mar 14, 2013 8:20 am | |
weekendwarriorfsw32
Posts : 22 Join date : 2013-03-18 Location : Bay area
| Subject: Re: Reverse gear upgrade Tue Mar 19, 2013 12:14 am | |
| If it pops out will it damage anything? | |
Quadog
| Subject: Re: Reverse gear upgrade Tue Mar 19, 2013 8:11 am | |
| I drove mine home after reverse went out...about a 10 mile trip. I've been advised not to drive it anymore untill it's fixed. Makes sense that something bad could happen. | |
| Subject: Re: Reverse gear upgrade Tue Mar 19, 2013 10:08 am | |
| yep...sometimes it breaks the cases | |
| Subject: Re: Reverse gear upgrade Tue Mar 19, 2013 10:27 am | |
| Along with the reverse gear upgrade if you already have the case split you might want to thank about doing the threw shaft also. There was something else James upgraded on mine when he built my 787 it was A plate of some kind I'm sure he can answer that for you better then me though just thangs to thank about when you are already in there and James can get everything for you that you need. | |
RADICAL RAM
| Subject: Re: Reverse gear upgrade Thu Apr 04, 2013 10:22 pm | |
| are the 660's known for this problem or just 700's?? im getting ready to split my cases on my 660 thanks | |
CamoRhino660
| Subject: Re: Reverse gear upgrade Thu Apr 04, 2013 10:33 pm | |
| Kyle why you tearing it down again? No this is not an issue on the 660. | |
| Subject: Re: Reverse gear upgrade | |
