In total there are 34 users online :: 0 Registered, 0 Hidden and 34 Guests :: 2 Bots
Oil cooler upgrade? Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Oil cooler upgrade? Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Oil cooler upgrade? Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Oil cooler upgrade? Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Oil cooler upgrade? Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Oil cooler upgrade? Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Oil cooler upgrade? Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Oil cooler upgrade? Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Oil cooler upgrade? Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Oil cooler upgrade? Vote_lcapOil cooler upgrade? Voting_barOil cooler upgrade? Vote_rcap
 Oil cooler upgrade?
5 posters
Bumpers
Bumpers
Oil cooler upgrade? Empty
PostSubject: Oil cooler upgrade?   Oil cooler upgrade? Icon_minitimeSat May 04, 2013 2:23 pm
Has anyone upgraded oil coolers and moved them? Mine has had its better days and the fins are all bent up from pressure washing and the sort. I was thinking of moving it or maybe getting on the ones with a small fan on it.. I know with the fins being jacked up and stuff its blocking a lot of airflow to the rad and also the hot air off the oil cooler is flowing through the rad itself. What say ye? anyone done this?
PostSubject: Re: Oil cooler upgrade?   Oil cooler upgrade? Icon_minitimeSat May 04, 2013 2:51 pm
Yes, I did it and am very happy with my relocation.
Check it out.
https://hotrodrhinoforums.forumotion.com/t955-under-my-hood?highlight=Under+my+hood
Bumpers
Bumpers
PostSubject: Re: Oil cooler upgrade?   Oil cooler upgrade? Icon_minitimeSun May 05, 2013 1:55 am
I seen tha .. I like it .. how did it effec the engine temps? Did it drop it much or about the same ?
PostSubject: Re: Oil cooler upgrade?   Oil cooler upgrade? Icon_minitimeFri May 10, 2013 6:57 am
I have not done it , but I would like to in the future mods never stop , but you would think when you move the oil cooler that it would help the radiator run a little cooler just from more air flow
P.S. Steve's looks great
PostSubject: Re: Oil cooler upgrade?   Oil cooler upgrade? Icon_minitimeFri May 10, 2013 11:23 am
Plus with twice as much fluid would it have more time to cool before it goes back into the motor or is this just a theory?
PostSubject: Re: Oil cooler upgrade?   Oil cooler upgrade? Icon_minitimeFri May 10, 2013 1:32 pm
x2 anytime you can increase the volume of your cooling fluid you will make it cool more efficiently.
(this is a setup for steve s.)
Oil cooler upgrade?
» Oil Cooler question?
» Engine Oil Cooler
» Radiator and oil cooler relocate
» Battery upgrade
» Reverse gear upgrade
