Who is online? | In total there are 31 users online :: 0 Registered, 0 Hidden and 31 Guests :: 2 Bots None Most users ever online was 207 on Tue Jun 11, 2013 11:13 pm |
| | Oil Cooler question? | |
| Subject: Oil Cooler question? Fri Apr 26, 2013 9:19 pm | |
| Removed the oil cooler to pressure wash it. Do I need to bleed anything when I put it back together? Do I just fill the oil, run it, and then add more oil? First time I've had it off so I'm not sure what I need to do when throwing it back together. Thanks | |
| | | REDRHINO64
| Subject: Re: Oil Cooler question? Fri Apr 26, 2013 9:23 pm | |
| I think it will prime itself,just crank it and let it run a couple mins,then recheck oil level. | |
| | | Pokahpolice
| Subject: Re: Oil Cooler question? Fri Apr 26, 2013 9:46 pm | |
| I was thinking the same thing but I'd like to be certain...anyone know for sure? | |
| | | REDRHINO64
| Subject: Re: Oil Cooler question? Fri Apr 26, 2013 9:50 pm | |
| When i do oil changes i take the oil lines loose and blow out the old oil,then hook them back up..crank it up for a couple of mins,then add oil to mark...never had any problems...im sure | |
| | | onebuilder
| Subject: Re: Oil Cooler question? Fri Apr 26, 2013 9:57 pm | |
| - Pokahpolice wrote:
- Removed the oil cooler to pressure wash it. Do I need to bleed anything when I put it back together? Do I just fill the oil, run it, and then add more oil? First time I've had it off so I'm not sure what I need to do when throwing it back together. Thanks
I know of one. Itis on the head, on the cam plug drivers side. | |
| | | Pokahpolice
| Subject: Re: Oil Cooler question? Fri Apr 26, 2013 10:09 pm | |
I know of one. Itis on the head, on the cam plug drivers side. So just treat it like any other bleeder...loosen until oil pisses out? | |
| | | onebuilder
| Subject: Re: Oil Cooler question? Fri Apr 26, 2013 10:26 pm | |
| I would let it leak out some and see if you get any air. The lines and oil passages probably still have oil in it. | |
| | | Pokahpolice
| Subject: Re: Oil Cooler question? Fri Apr 26, 2013 10:28 pm | |
| Subject: Re: Oil Cooler question? | |
