| Reverse gear upgrade | |
+1208Rhino450SE CamoRhino660 RADICAL RAM T.Rhino weekendwarriorfsw32 bhawk southark tjt603 WV Hot Rod Rhino Firefighter LouisianaRebel Quadog 16 posters |
Quadog
Quadog
| Subject: Re: Reverse gear upgrade Wed Apr 17, 2013 9:06 am | |
| Subject: Re: Reverse gear upgrade Wed Apr 17, 2013 11:37 am | |
| forgot about the valkyries. they were real groundpounders. yeah, i remember the 900s as well as the 500s and 400s triples. first time i rode a 400 the front wheel came off the ground at about 5000 rpm and i just hung on. what a rush. | |
Quadog
| Subject: Re: Reverse gear upgrade Fri Apr 26, 2013 10:51 am | |
Quadog
| Subject: Re: Reverse gear upgrade Fri Apr 26, 2013 10:52 am | |
Quadog
Quadog
| Subject: Re: Reverse gear upgrade Fri Apr 26, 2013 10:54 am | |
| Subject: Re: Reverse gear upgrade Fri Apr 26, 2013 1:03 pm | |
| hell I had a year of saving $$$ for parts an don't doubt that I have three times your hours , but on the chain loose are you on the oil pump chain, my oil pump chain was loose also did not see diff in the new one . also I still have my 76 KZ 900 in the barn wish it looked as good as yours mine has the z1 top end and in the day was a fun little ride, make me want to start another project, but back to your project check your middle drive support don't know if its like the 660 ifso might upgrade while your in that deep | |
EddieMc
| Subject: Re: Reverse gear upgrade Fri Apr 26, 2013 6:56 pm | |
| man mines already apart like this from the dealer how much is the gear??? | |
Quadog
| Subject: Re: Reverse gear upgrade Sat Apr 27, 2013 10:31 am | |
| The gear is 15-20 dollars. Same for the chain | |
| Subject: Re: Reverse gear upgrade Sat Apr 27, 2013 12:09 pm | |
| are you talking oil pump gear& chain if so quadog all over it , if you talking cam chain I think I gave 60.00 I think been awhile I found billit middle gear support for 100.00 again i think good luck on it | |
| Subject: Re: Reverse gear upgrade Sat Apr 27, 2013 12:12 pm | |
| i missed the part of at the dealer you better call James to save some | |
EddieMc
| Subject: Re: Reverse gear upgrade Sat Apr 27, 2013 2:22 pm | |
| I just need the gear right? | |
| Subject: Re: Reverse gear upgrade Sun Apr 28, 2013 1:35 am | |
| call James about your gear he can set you up | |
Quadog
| Subject: Re: Reverse gear upgrade Sun Apr 28, 2013 11:52 am | |
Quadog
| Subject: Re: Reverse gear upgrade Sun Apr 28, 2013 11:53 am | |
Quadog
| Subject: Re: Reverse gear upgrade Sun Apr 28, 2013 11:54 am | |
Quadog
Quadog
Quadog
Quadog
Quadog
bhawk
Posts : 15 Join date : 2013-03-11 Location : Watkins, Colorado
| Subject: Re: Reverse gear upgrade Sun Apr 28, 2013 12:54 pm | |
| I hear ya! Can't believe all the work that needs to be done because a c-clip slid over. For me it was a bleesing because the the 4 bolts that hold the final gear drive backed out and were floating around the engine. May want to check them. I know they have backed out on others also and put a hole in the case. Just think your not quite half way yet. | |
| Subject: Re: Reverse gear upgrade Sun Apr 28, 2013 3:16 pm | |
| I would check your middle drive support housing while your there if Yamaha has not fixed the pot metal crap that was in mine I would get the billit middle support , the pot metal known for braking an taking out a lot more in the bottom end .... just my thought while you got it apart | |
| Subject: Re: Reverse gear upgrade | |
