| Reverse gear upgrade | |
+1208Rhino450SE CamoRhino660 RADICAL RAM T.Rhino weekendwarriorfsw32 bhawk southark tjt603 WV Hot Rod Rhino Firefighter LouisianaRebel Quadog 16 posters |
RADICAL RAM
| Subject: Re: Reverse gear upgrade Thu Apr 04, 2013 10:37 pm | |
| - CamoRhino660 wrote:
- Kyle why you tearing it down again? No this is not an issue on the 660.
it started burning oil last fall bad enough to foul plugs. this is after i bored the cylinder installed new piston and rings. thats why i tore into the engine. after tearing into it discovered that my new rod is way sloppy on my crank pin so i have to split the cases again. | |
RADICAL RAM
| Subject: Re: Reverse gear upgrade Thu Apr 04, 2013 10:44 pm | |
CamoRhino660
| Subject: Re: Reverse gear upgrade Thu Apr 04, 2013 10:54 pm | |
| Well that sucks!! Sorry to hear that. You put all new parts in it dident you? | |
RADICAL RAM
| Subject: Re: Reverse gear upgrade Thu Apr 04, 2013 10:56 pm | |
RADICAL RAM
| Subject: Re: Reverse gear upgrade Fri Apr 05, 2013 7:17 am | |
- Well that sucks!! Sorry to hear that. You put all new parts in it dident you?
Yeah new rod, piston and rings. not sure if crank pin is new. does that normally come with the rod. | |
Quadog
Quadog
| Subject: Re: Reverse gear upgrade Mon Apr 08, 2013 11:30 am | |
Quadog
Quadog
| Subject: Re: Reverse gear upgrade Mon Apr 08, 2013 11:36 am | |
| I got it on the bench. Got the primary sheave off but I can't get the secondary off. Tried it with an impact forward and reverse. It is sitting with wd40 on it now. Done enough for one day. I think it is counterclockwise... Right? Damn already stuck ...LOL | |
Quadog
| Subject: Re: Reverse gear upgrade Mon Apr 08, 2013 11:40 am | |
| Or clockwise I think... Left thread? | |
| Subject: Re: Reverse gear upgrade Mon Apr 08, 2013 11:53 am | |
| same as primary...lefty loosy | |
Quadog
| Subject: Re: Reverse gear upgrade Mon Apr 08, 2013 1:00 pm | |
| Ok Thanks. I gotta get a 22m impact socket. I only had a regular socket & it was starting to look like a bell at the end. | |
Quadog
| Subject: Re: Reverse gear upgrade Tue Apr 16, 2013 8:44 am | |
Quadog
| Subject: Re: Reverse gear upgrade Tue Apr 16, 2013 8:45 am | |
Quadog
| Subject: Re: Reverse gear upgrade Tue Apr 16, 2013 8:46 am | |
Quadog
| Subject: Re: Reverse gear upgrade Tue Apr 16, 2013 8:47 am | |
Quadog
| Subject: Re: Reverse gear upgrade Tue Apr 16, 2013 8:48 am | |
Quadog
Quadog
bhawk
Posts : 15 Join date : 2013-03-11 Location : Watkins, Colorado
| Subject: Re: Reverse gear upgrade Tue Apr 16, 2013 2:00 pm | |
| Just got mine all back together form doing the reverse gear. In a way it was a blessing because I had 2 bolts floating around in there. The had backed out from the final gear drive. The 3rd one was half way out and the 4th one was finger tight. May want to check them when it is apart. Loctite EVERYTHING. Man that was a job and a half. | |
| Subject: Re: Reverse gear upgrade Tue Apr 16, 2013 2:11 pm | |
Quadog
Quadog
| Subject: Re: Reverse gear upgrade Tue Apr 16, 2013 8:49 pm | |
| - bhawk wrote:
- Just got mine all back together form doing the reverse gear. In a way it was a blessing because I had 2 bolts floating around in there. The had backed out from the final gear drive. The 3rd one was half way out and the 4th one was finger tight. May want to check them when it is apart. Loctite EVERYTHING. Man that was a job and a half.
Did you upgrade anything while you were at it? | |
| Subject: Re: Reverse gear upgrade Tue Apr 16, 2013 10:10 pm | |
| - Quadog wrote:
Parts Everywhere & still haven't got the engine apart .
The bed is a handy parts bin though. is that an old wing (scoot)? i think i can see 3 downtubes or maybe it's the spirits... | |
bhawk
| Subject: Re: Reverse gear upgrade Tue Apr 16, 2013 10:22 pm | |
| Put in a 11:1 cp piston,all new clutch with slugs,upgraded to msd 3d. I have 2300 miles on mine. They at it can be done in 12-14 hours. Maybe if your a pro. I had at least 35 man hours start to finish. | |
| Subject: Re: Reverse gear upgrade | |
