In total there are 42 users online :: 0 Registered, 0 Hidden and 42 Guests :: 2 Bots
adjusting tps on 700 rhino Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
adjusting tps on 700 rhino Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
adjusting tps on 700 rhino Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
adjusting tps on 700 rhino Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
adjusting tps on 700 rhino Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
adjusting tps on 700 rhino Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
adjusting tps on 700 rhino Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
adjusting tps on 700 rhino Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
adjusting tps on 700 rhino Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
adjusting tps on 700 rhino Vote_lcapadjusting tps on 700 rhino Voting_baradjusting tps on 700 rhino Vote_rcap
3 posters
rhinopg
adjusting tps on 700 rhino Empty
PostSubject: adjusting tps on 700 rhino   adjusting tps on 700 rhino Icon_minitimeMon Nov 11, 2013 2:55 pm
Hi,I just watched James video on the 700 tps ,I n the video james said the numbers are 95 to 100 when the gas peddle is fully depressed,On my 700 the reading was 94,how do I adjust the tps to get the numbers where they should be.thank you.
PostSubject: Re: adjusting tps on 700 rhino   adjusting tps on 700 rhino Icon_minitimeMon Nov 11, 2013 3:33 pm
yours is prolly the cable free play is to much
rhinopg
PostSubject: Re: adjusting tps on 700 rhino   adjusting tps on 700 rhino Icon_minitimeMon Nov 11, 2013 9:19 pm
Thankyou James, what it the procedure to take out the slack in the throttle cable and what number between 95 and 100 should I set it at,thanks again.
RHINOMOON
RHINOMOON
PostSubject: Re: adjusting tps on 700 rhino   adjusting tps on 700 rhino Icon_minitimeThu Nov 21, 2013 8:25 pm
17-95  i think im good
» ADJUSTING VALVES
» help adjusting the gear select shifter
» Hot Rod & T.Rhino
» My 450 Rhino
» why did you buy a rhino?
