In total there are 15 users online :: 0 Registered, 0 Hidden and 15 Guests
Dynatek cdi on 660 Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Dynatek cdi on 660 Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Dynatek cdi on 660 Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Dynatek cdi on 660 Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Dynatek cdi on 660 Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Dynatek cdi on 660 Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Dynatek cdi on 660 Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Dynatek cdi on 660 Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Dynatek cdi on 660 Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Dynatek cdi on 660 Vote_lcapDynatek cdi on 660 Voting_barDynatek cdi on 660 Vote_rcap
 Dynatek cdi on 660
5 posters
Deuces wild
Deuces wild
Dynatek cdi on 660 Empty
PostSubject: Dynatek cdi on 660   Dynatek cdi on 660 Icon_minitimeThu Mar 14, 2013 10:11 pm
Do I need to re-jet my 660 after I changed the cdi.?
Deuces wild
Deuces wild
PostSubject: Re: Dynatek cdi on 660   Dynatek cdi on 660 Icon_minitimeThu Mar 14, 2013 10:14 pm
I forgot to add that I have NGO iridium plug don't know if that makes a difference.
PostSubject: Re: Dynatek cdi on 660   Dynatek cdi on 660 Icon_minitimeThu Mar 14, 2013 10:26 pm
No, but You will probably want to get a siphon break. What happens is the aftermarket CDI allows You to run higher RPM, Thus causing the intake to start sucking oil out of the crankcase. It is an easy fix and JBS has them. It really only happens when You run WOT for a while, and You will.
PostSubject: Re: Dynatek cdi on 660   Dynatek cdi on 660 Icon_minitimeThu Mar 14, 2013 10:27 pm
Dynatek cdi on 660 Images?q=tbn:ANd9GcQ7vL_0nuoHhwA8MxPAuGkb5WVCetuAt9fzAeDavlxCBCUnDttd
muddslinger
PostSubject: Re: Dynatek cdi on 660   Dynatek cdi on 660 Icon_minitimeThu Mar 14, 2013 10:32 pm
X2
Deuces wild
Deuces wild
PostSubject: Re: Dynatek cdi on 660   Dynatek cdi on 660 Icon_minitimeThu Mar 14, 2013 10:38 pm
Thanks guys! Im new to this rhino thing but one thing I know for sure is that James has to be kin to Santa clause because he has all the good stuff
PostSubject: Re: Dynatek cdi on 660   Dynatek cdi on 660 Icon_minitimeThu Mar 14, 2013 10:47 pm
I think their cousins ! lol
PostSubject: Re: Dynatek cdi on 660   Dynatek cdi on 660 Icon_minitimeFri Mar 15, 2013 1:17 am
that must be the best job ever....lol
PostSubject: Re: Dynatek cdi on 660   Dynatek cdi on 660 Icon_minitimeFri Mar 15, 2013 11:26 am
never knew what the siphon break was used for might look into one also are they expensive?
Dynatek cdi on 660
» dynatek 660 cdi
» Dynatek cdi
» Dynatek Coil
» Dynatek non programmable CDI For 660 make offer
