| Irridium Spark plug | |
+11Kenny G muddslinger Garnog Firefighter jdsande3 LJB Clay44 madmax 1 watrsmkr Yotehunter66 hymarker 15 posters |
hymarker
| Subject: Irridium Spark plug Sun Mar 10, 2013 6:59 pm | |
| Any use these and are they worth the extra money? | |
Yotehunter66 Moderator
| Subject: Re: Irridium Spark plug Sun Mar 10, 2013 7:16 pm | |
| Yes. Coupled with an aftermarket CDI And mine starts up a lot faster. | |
watrsmkr
Posts : 24 Join date : 2013-03-10 Age : 66 Location : Ohio
| Subject: Re: Irridium Spark plug Sun Mar 10, 2013 7:40 pm | |
| Running anE3.36 in my 2007....seems to start and run a little better. | |
hymarker
| Subject: Re: Irridium Spark plug Sun Mar 10, 2013 7:42 pm | |
| Nice. Thanks prob time for a new plug and thought I'd give them a try. | |
| Subject: Re: Irridium Spark plug Sun Mar 10, 2013 8:38 pm | |
| have ran both e3 and ngk iridum bothseem to start and run better than stock | |
Clay44
Posts : 40 Join date : 2013-03-10 Age : 45 Location : Texas
| Subject: Re: Irridium Spark plug Sun Mar 10, 2013 8:40 pm | |
| What number for ngk plug? | |
LJB
Posts : 2 Join date : 2013-03-10
| Subject: Re: Irridium Spark plug Sun Mar 10, 2013 8:41 pm | |
| yep, they are worth the extra money | |
jdsande3
Posts : 18 Join date : 2013-03-10
| Subject: Re: Irridium Spark plug Sun Mar 10, 2013 9:14 pm | |
| I have one in my 700. I didn't notice too much of a difference, but I have a 2012 and was trying to hold off buying a controller until MSD released one. Looks like I may be waiting a while. | |
| Subject: Re: Irridium Spark plug Mon Mar 11, 2013 11:24 am | |
| - Clay44 wrote:
- What number for ngk plug?
X 2 | |
Garnog
Posts : 46 Join date : 2013-03-10 Location : Moundtown, WV
| Subject: Re: Irridium Spark plug Mon Mar 11, 2013 11:41 am | |
| Need part number for 700 plug. | |
watrsmkr
| Subject: Re: Irridium Spark plug Mon Mar 11, 2013 3:35 pm | |
Garnog
| Subject: Re: Irridium Spark plug Wed Mar 13, 2013 1:27 pm | |
| NGK 9198 for 700. Rock Auto has a great price and cheap shipping. Got two for S15.00. | |
muddslinger
Posts : 16 Join date : 2013-03-14 Age : 53 Location : southern west virginia
| Subject: Re: Irridium Spark plug Fri Mar 15, 2013 10:22 pm | |
| i've been running one in my 686 with a dynatek cdi and it dif. makes a diffence on starts... | |
| Subject: Re: Irridium Spark plug Mon Mar 18, 2013 12:10 am | |
| Put an Irridium plug in my 06/450 this weekend before taking off riding. To be truthful; I really didn't notice any difference, have a Dyna FS on the bike and could really tell a difference when I put it on. Do you gap the Irridium the same? Might be a dumb question but just asking beings the firing end is different. | |
| Subject: Re: Irridium Spark plug Wed Mar 27, 2013 8:06 pm | |
| I think it helps, it enough where its the only one I will replace it with. | |
| Subject: Re: Irridium Spark plug Wed Mar 27, 2013 8:27 pm | |
| Most of the CDIs I believe increase the spark voltage. Coupled with a good plug makes the difference. | |
Deuces wild
| Subject: Re: Irridium Spark plug Wed Mar 27, 2013 9:02 pm | |
| The only thing I have done to my bike is ngk iridium plug and dynatek cdi and I honestly think it made a difference. | |
Deuces wild
| Subject: Re: Irridium Spark plug Wed Mar 27, 2013 9:04 pm | |
| Faster starting and not AS cold natured. | |
| Subject: Re: Irridium Spark plug Fri Mar 29, 2013 2:05 pm | |
| are the iridium plugs hotter ? | |
| Subject: Re: Irridium Spark plug Fri Mar 29, 2013 5:29 pm | |
| Whats the part # for the 660 iridium plug? | |
| Subject: Re: Irridium Spark plug Fri Mar 29, 2013 9:14 pm | |
| - rhino727 wrote:
- are the iridium plugs hotter ?
Your copper plug conducts better than iridium (iridium is a type of metal). Iridium doesn't erode like copper. They have a slightly better conductor and produce a better spark under modifies engine with higher compression. What I've read; on an unmodified engine you will not see much of any difference. You will see longer plug life with iridium as the copper plug will erode and the spark will become less powerful. Also, you shouldn't try and gap an Iridium plug, you can damage the tip. This information is from my researching the Iridium plug, I personal didn't notice any difference when I installed the Iridium plug in my Rhino with a stock engine. | |
Garnog
| Subject: Re: Irridium Spark plug Mon Apr 01, 2013 1:28 pm | |
| NGK 2202 worked great in my 660. | |
| Subject: Re: Irridium Spark plug | |
