Subject: Is the noise worth it? Sat Mar 16, 2013 8:48 pm
I just put a Dynatek cdi and irridium plug on my 660 and really woke it up but have stock exhaust. Is it worth the noise of changing the exhaust will it be any different?
DEZLFREK
Posts : 52 Join date : 2013-03-15 Age : 52 Location : sonoma ca
Subject: Re: Is the noise worth it? Sat Mar 16, 2013 10:11 pm
i run stock exhaust also but i dont like loud. i modified it a little to help by cutting the tip off as it made the outlet a little bigger and drilled a hole about the same size in the baffle inside also to help with flow.. both of those mods made it only slightly louder but kept the spark arrestor and from my air fuel guage made it leaner also so it helped to make more power without much noise..
Subject: Re: Is the noise worth it? Sat Mar 23, 2013 7:33 pm
I have a Jardine RT5 complete exhaust,I really felt the power but,my ears were ringing after a ride, even with a full helmet,and almost everyone I met that heard said "thats pretty loud",so I took it off.Since the then its become illegal to use it,$200 to have it and a $500 fine to sell it.
Subject: Re: Is the noise worth it? Sat Mar 23, 2013 7:44 pm
The $500 fine sucks. Are you allowed to have any aftermarket exhaust or is it just a noise law ?
Subject: Re: Is the noise worth it? Sat Mar 23, 2013 7:51 pm
I done an exhaust tip from Weller racing. It has a bigger inside diameter and sounds a lot deeper. It may only be in my mind, but it seem to help a lot more than I thought it would. I was able to use the factory spark arrestor with it. Duals or something like the Alba pipe will increase the horses, but dont think I could handle the noise.
Subject: Re: Is the noise worth it? Sat Mar 23, 2013 8:26 pm
The Alba isnt too bad
Subject: Re: Is the noise worth it? Sat Mar 23, 2013 9:07 pm
I got a tip on mine and like it, but I wouldn't want it any louder.
Deuces wild
Subject: Re: Is the noise worth it? Sat Mar 23, 2013 9:18 pm
The other day I took the stock tip and spark arrestor out, is that what putting a tip on sounds like?
Subject: Re: Is the noise worth it? Sat Mar 23, 2013 9:20 pm
I tried that, to me , its a deeper sound with the tip
Subject: Re: Is the noise worth it? Sat Mar 23, 2013 9:26 pm
Watch a couple of these vids. You can hear some of the exhaust tip.
Subject: Re: Is the noise worth it? Sat Mar 23, 2013 9:28 pm
Yeah, pretty much. It does lean them out a little. Mine sounded better after James put the final tune on it. Nice deep sound at slow speeds, and downhill. It does help flow. I don't know how much, but mine wouldn't idle for very long after we put it on. Had to add a little fuel.
Subject: Re: Is the noise worth it? Sun Mar 24, 2013 9:40 am
After market exhaust on your own land only,and no riding after 11:00pm.
Subject: Re: Is the noise worth it? Sun Mar 24, 2013 10:25 am
so to ride anyplace other then your own land you have to have the stock exhaust ? I guess I could live with the stock exhaust
Subject: Re: Is the noise worth it? Mon Mar 25, 2013 8:39 pm
you may want to check out the Gibson exhaust good performer not to load
Deuces wild
Subject: Re: Is the noise worth it? Sun Mar 31, 2013 10:23 pm
If I change the tip do I need to re-jet? If so what? The reason I ask is if I put a tip on I'm probably going to be switching back and forth. That's the reason I don't want to go full blown exhaust, this may be the best of both worlds for me...
Subject: Re: Is the noise worth it? Sun Mar 31, 2013 11:32 pm
I would say you will need to re-jet. I don't think you would want to switch back and fourth after you get the tip and get it jetted good. It's not really much louder if any other than sounding a whole lot better at a slow crawl, and having a deeper idle. Pull you stock one and ride it to see what it runs like with no tip. That's what it will run like with the aftermarket tip on.
Deuces wild
Subject: Re: Is the noise worth it? Sun Mar 31, 2013 11:36 pm
Is it to loud to hunt off of? That's why I say I would switch back an forth. No way you can have quite and performance is it?
Subject: Re: Is the noise worth it? Sun Mar 31, 2013 11:41 pm
I agree with Hump. I dont think You will want to switch back once You get it on. It is really just a deeper sound, especially at lower speeds
Deuces wild
Subject: Re: Is the noise worth it? Sun Mar 31, 2013 11:45 pm
Who makes the best tip?
Subject: Re: Is the noise worth it? Sun Mar 31, 2013 11:46 pm
It's a much deeper performance tone, but not much louder at all. Absolutely nothing like a aftermarket exhaust. With the tip, your clutch weights and belt running up and down the sheaves are still almost as loud. Pull you stock one and see what you think...that's how loud it will be, but it will sound better once it's jetted right.
Subject: Re: Is the noise worth it? Sun Mar 31, 2013 11:49 pm
James put mine on, and I have no idea what it was. It is a polished aluminum one with a screen to go behind it so you will be legal. We didn't put the screen in. I don't go to H&M to ride much, plus it's not loud enough for them to want to check it anyway. Most of the tips like mine look the same. They are all over ebay.
Deuces wild
Subject: Re: Is the noise worth it? Mon Apr 01, 2013 12:20 am
What jets did you use?
Subject: Re: Is the noise worth it? Mon Apr 01, 2013 12:27 am
I run the Gibson exhaust and I love the way mine sounds. It is louder than stock for sure but not overly loud by any means.
Subject: Re: Is the noise worth it? Mon Apr 01, 2013 1:25 am
Mine is a 700 FI, so it was tuned with a fuel controller. Do you have a sheave yet?
Deuces wild
Subject: Re: Is the noise worth it? Mon Apr 01, 2013 11:37 pm
