| cab noise | |
+3watrsmkr Firefighter madmax 1 7 posters |
| Subject: cab noise Fri Mar 29, 2013 4:52 pm | |
| when i close in my cab for winter it is pretty noisy , just wanted to see what everybody else does to quiet things down, a lot of the noise is the air intake thought about some type of snorkel,what do you guys thinl? | |
| Subject: Re: cab noise Fri Mar 29, 2013 5:01 pm | |
| Ryde on dust cover from JBS and run You intake 04 style ! | |
| Subject: Re: cab noise Fri Mar 29, 2013 5:02 pm | |
| any pics of 04 style intake | |
| Subject: Re: cab noise Fri Mar 29, 2013 5:05 pm | |
| 04 style is simply removing the factory snorkel that connects the air box to the engine cover. This allows for more air to the air box, thus more power ! Ther are a couple of options. 1. You can then close off the inlet on the engine cover. Make it a LOT quieter ! 2. You can do a rais tube. This is simply a vacuum hose attachment which has a bigger inside diameter than the factory snorkel. Uses factory engine cover inlet but allows for more air = more power
| Subject: Re: cab noise Fri Mar 29, 2013 5:06 pm | |
| I have mine 04 style and the inlet in the engine cover is blocked off. LOTS quieter. Not for running deep water though | |
| Subject: Re: cab noise Fri Mar 29, 2013 5:08 pm | |
| i have the rais tube, but you mean to remove the air box lid and cover the intake inside cab? | |
| Subject: Re: cab noise Fri Mar 29, 2013 5:19 pm | |
| Leave the lid on and just take the rais tube off. Then You can plug the vent hole on the engine cover | |
| Subject: Re: cab noise Fri Mar 29, 2013 5:24 pm | |
| Subject: Re: cab noise Fri Mar 29, 2013 5:28 pm | |
| thanks man i know what you mean now!! | |
watrsmkr
Posts : 24 Join date : 2013-03-10 Age : 66 Location : Ohio
| Subject: Re: cab noise Fri Mar 29, 2013 5:35 pm | |
| Do you need to rejet if you remove the tube and block the whole? | |
| Subject: Re: cab noise Fri Mar 29, 2013 5:37 pm | |
| Most likely. removing the factory tube allows more air in the intake. | |
| Subject: Re: cab noise Fri Mar 29, 2013 9:33 pm | |
| Did you rejet firefighter. | |
| Subject: Re: cab noise Fri Mar 29, 2013 9:49 pm | |
| Yes, 45 / 155 but that was just a lucky guess. Need an A/F guage | |
| Subject: Re: cab noise Sun Mar 31, 2013 4:23 pm | |
| Yeah I'm just not going to mess with it. I don't like to break down. lol | |
| Subject: Re: cab noise Fri Apr 05, 2013 12:44 pm | |
Crusty
| Subject: Re: cab noise Wed Aug 14, 2013 4:22 pm | |
| I really like 08Rhino450SE's option. not only does it help quiet down the Rhino but it also helps in the home, truck, camping and it even works in bed.lol | |
| Subject: Re: cab noise Wed Aug 14, 2013 4:36 pm | |
| I have the porcupine seat covers,love them. | |
| Subject: Re: cab noise | |
| cab noise | |
