RHINOMOON
| Subject: noise when putting into L or H Mon Aug 26, 2013 2:54 pm | |
| sometimes i get a , erch, noise. i put it in low or high, then give it gas. it engauges ,a bit after when it should. not all the time just once in a while, but when it engauges it makes the noise, drives fine after, just on initial gear select. look in my sig for mods, everything has been done. no issues after any mods, just started happin latly, maybe wet clutch startin to go? thanks for the help. | |
| Subject: Re: noise when putting into L or H Mon Aug 26, 2013 2:59 pm | |
| if its a belt chirp the sheaves needs serviced with the proper grease | |
| Subject: Re: noise when putting into L or H Mon Aug 26, 2013 3:29 pm | |
| Sometimes mine will chirp on takeoff if I come to an abrupt stop. That's when I know the sheaves need to be serviced. I think the weights get dirty and don't slide properly. It's probably the sheave not closing completely and when you take off the belt may not be tight. | |
| Subject: Re: noise when putting into L or H Mon Aug 26, 2013 3:58 pm | |
| worn fixed will do it too | |
| Subject: Re: noise when putting into L or H Mon Aug 26, 2013 4:08 pm | |
| Good stuff. Thanks for the advice James. | |
RHINOMOON
| Subject: Re: noise when putting into L or H Tue Aug 27, 2013 3:21 pm | |
| ok thanks guys, its was probly when i got stuck in a soupy clay mud hole. | |
| Subject: Re: noise when putting into L or H | |
