| Sheave noise | |
Dan700
Posts : 23 Join date : 2013-03-31
| Subject: Sheave noise Fri Apr 26, 2013 1:41 pm | |
| I finally got around installing my sheave got everything back together. started up and hit the gas pedal and made a lil noise like something was lose like a rattle. But it doesn't do it all the time seems like it performs all good I get about 48-49 mph went for about a 1 mile ride everything performs good only heard the rattle 1 or 2 times something to be concerned with? thanks dan | |
| Subject: Re: Sheave noise Fri Apr 26, 2013 1:44 pm | |
| Did you put the stocker or JBS on and if so is it greased or greaseless? | |
Dan700
| Subject: Re: Sheave noise Fri Apr 26, 2013 1:50 pm | |
| Subject: Re: Sheave noise Fri Apr 26, 2013 2:06 pm | |
| Did you get the bracket on the primary tight? | |
| Subject: Re: Sheave noise Fri Apr 26, 2013 2:28 pm | |
| Dan, I have a similar noise in mine. Only at low end take off. Have not found anything loose in the CVT, but it sure sounds like it is coming from there. Been that way for several months with no issues. | |
| Subject: Re: Sheave noise Fri Apr 26, 2013 2:30 pm | |
| james will probably give his input , no problems to date with mine but great performance | |
| Subject: Re: Sheave noise Fri Apr 26, 2013 2:32 pm | |
| Now that I think about it, I don't know if I have heard it since I put new sheave in !
I'll listen for it this weekend. | |
| Subject: Re: Sheave noise Fri Apr 26, 2013 2:37 pm | |
| I don't know, I got to many noises everywhere else:lol!: The bed rattles sometimes and I have a grinding noise up front. Maybe because at takeoff the weights are tight against the camplate on the newer style ones firefighter, I just did mine and its great! | |
| have you been out hiking or you just gettin old like me | |
Dan700
| Subject: Re: Sheave noise Fri Apr 26, 2013 2:40 pm | |
| Thanks for input.. everything seems performing great just heard it a couple times... haven't had a lot of time to test it though | |
| Subject: Re: Sheave noise Fri Apr 26, 2013 2:41 pm | |
| shouldnt be any noise...maybe one way wore some?? | |
| Subject: Re: Sheave noise Fri Apr 26, 2013 2:45 pm | |
| - WV Hot Rod Rhino wrote:
- shouldnt be any noise...maybe one way wore some??
Maybe a worn one way making some noise with the added engine braking from new sheave set up ? | |
| Subject: Re: Sheave noise Fri Apr 26, 2013 2:49 pm | |
| I hardly even use the brakes any more! Specially when everythings warmed up! | |
| Subject: Re: Sheave noise Fri Apr 26, 2013 2:51 pm | |
| Maybe loose nut behind the wheel! LOL! | |
| Subject: Re: Sheave noise Fri Apr 26, 2013 3:08 pm | |
| - onebuilder wrote:
- Maybe loose nut behind the wheel! LOL!
Most likely ! I've had a rattle between the ears since 40 !!! OK Probably 30, but who is counting. | |
| Subject: Re: Sheave noise Fri Apr 26, 2013 3:17 pm | |
| - Firefighter wrote:
Most likely ! I've had a rattle between the ears since 40 !!! OK Probably 30, but who is counting. Lol! Same here. I couldn't resist... TGIF and only one more week until I go on vacation! | |
| Subject: Re: Sheave noise | |
| Sheave noise | |
