| Troubles on the trail | |
+12madmax 1 JOHN DILLARD chuddly Quadog thekevin Kenny G WV Hot Rod Rhino REDRHINO64 Yotehunter66 Firefighter Greeley timbuck 16 posters |
timbuck
Posts : 23 Join date : 2013-03-21 Age : 65 Location : Arkansas
| Subject: Re: Troubles on the trail Sun Mar 24, 2013 7:11 pm | |
| Well,... today I took the fuel tank out and dumped it, rinsed it out with freash gas and re-installed and filled with fresh gas. Guess what, still nothing!!! it wants to fire but doing the same thing. I gave it plenty of time to get the air out of the lines. It goes to the shop tomorrow!!! | |
| Subject: Re: Troubles on the trail Sun Mar 24, 2013 7:30 pm | |
| Well That stinks. Maybe it will still be something simple. | |
Yotehunter66 Moderator
| Subject: Re: Troubles on the trail Sun Mar 24, 2013 9:30 pm | |
| Electric fuel pump or vacuum pump? Can you pull the line from the pump to the carb and crank it to see if your getting steady fuel? | |
timbuck
| Subject: Re: Troubles on the trail Mon Mar 25, 2013 9:33 am | |
| Subject: Re: Troubles on the trail Mon Mar 25, 2013 9:46 am | |
timbuck
| Subject: Re: Troubles on the trail Mon Mar 25, 2013 12:28 pm | |
| Hey Hot Rod, It is in the shop now.... What secondary sheave would you recommend for low end performance? I want more power on take off and climbing, not on overall speed. Thanks, Timbuck | |
| Subject: Re: Troubles on the trail Mon Mar 25, 2013 12:51 pm | |
| If the Sheaves are identical to a Rhino, He has one that will really impress You. I need to come up and let You take mine for a drive ! | |
| Subject: Re: Troubles on the trail Mon Mar 25, 2013 12:53 pm | |
| secondary spring? or sheave kit | |
| Subject: Re: Troubles on the trail Mon Mar 25, 2013 12:56 pm | |
| Let Him take mine for a spin, He will want both !!! And anti friction washers ! | |
| Subject: Re: Troubles on the trail Mon Mar 25, 2013 5:58 pm | |
timbuck
| Subject: Re: Troubles on the trail Mon Mar 25, 2013 8:27 pm | |
| I will,... I would like to get a sheave kit after I get it fixed. | |
| Subject: Re: Troubles on the trail Tue Mar 26, 2013 4:35 pm | |
| If it is as close to a Rhino as I'am thinking and its E.F.I.if possible disconnect the fuel line at the pump and check for fuel,if there is now fuel pressure you could try and swap one of the relays to the fuel pump relay possition,I had my relay click it would supply voltage but not enough current to turn the fuel pump motor! Check coil and plug lead,check the connections under the passenger seat for water or dirt,green death(corrosion on copper). | |
timbuck
| Subject: Re: Troubles on the trail Tue Mar 26, 2013 6:10 pm | |
| Just got it back from the dealer. It was a bad spark plug wire. I should have checked the continuity, but I didn't! They replaced the spark plug as well. It runs like a scalded ape now. Thanks for all your advice! I am ready for a sheave kit now.... | |
| Subject: Re: Troubles on the trail Tue Mar 26, 2013 6:12 pm | |
| Subject: Re: Troubles on the trail Tue Mar 26, 2013 6:17 pm | |
| Man! Glad You got it fixed ! | |
timbuck
| Subject: Re: Troubles on the trail Tue Mar 26, 2013 7:34 pm | |
| Thanks! I am pretty stoked! | |
| Subject: Re: Troubles on the trail Sun Mar 31, 2013 8:39 am | |
| Congrats. Glad it was something simple. | |
| Subject: Re: Troubles on the trail Sun Mar 31, 2013 9:01 am | |
| Good deal!!...Now get to riding!! lol:twisted: | |
| Subject: Re: Troubles on the trail Sun Mar 31, 2013 11:44 am | |
| Its always a relief when its not something major. Which sheave fits the 450 or 660? | |
| Subject: Re: Troubles on the trail | |
