In total there are 21 users online :: 0 Registered, 0 Hidden and 21 Guests :: 2 Bots
wheel spacers Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
wheel spacers Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
wheel spacers Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
wheel spacers Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
wheel spacers Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
wheel spacers Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
wheel spacers Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
wheel spacers Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
wheel spacers Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
wheel spacers Vote_lcapwheel spacers Voting_barwheel spacers Vote_rcap
 wheel spacers
cumnz
DesertRhino1301
Rootin'Rhino
Deuces wild
superchevy
Yotehunter66
tjt603
RiverRat
19 posters
Go to page : 1, 2  Next
wheel spacers Empty
PostSubject: wheel spacers   wheel spacers Icon_minitimeSat Mar 23, 2013 3:55 pm
never did the factory recall thing with the sway bar just removed it myself, but now wondering if the rear spacers would help,what do you guys think?
RiverRat
RiverRat
wheel spacers Empty
PostSubject: Re: wheel spacers   wheel spacers Icon_minitimeSat Mar 23, 2013 4:10 pm
I think it helped on mine. They were on it when I purchased it though. Seems to be wider in the rear though.
tjt603
tjt603
wheel spacers Empty
PostSubject: Re: wheel spacers   wheel spacers Icon_minitimeSat Mar 23, 2013 5:38 pm
it helped mine big time
Yotehunter66
Moderator
Yotehunter66
wheel spacers Empty
PostSubject: Re: wheel spacers   wheel spacers Icon_minitimeSat Mar 23, 2013 6:12 pm
I don't have them on mine either. Since the sway bar is still there I'm assuming the recall was never done.
superchevy
superchevy
wheel spacers Empty
PostSubject: Re: wheel spacers   wheel spacers Icon_minitimeSat Mar 23, 2013 7:37 pm
I took mine to the local Yamaha dealer and they removed my sway bar added the wheel spacers and give me a new helmet. I rode it when I got it back home and noticed it handled alot better and rode better in the type of terrain I ride in. I would definitely get the wheel spacers put on and leave that sway bar off.
wheel spacers Empty
PostSubject: Re: wheel spacers   wheel spacers Icon_minitimeSat Mar 23, 2013 8:05 pm
I had to take my spacers off when I picked up my new Rhino because it wouldn't on my 5 ft. wide trailer.
wheel spacers Empty
PostSubject: Re: wheel spacers   wheel spacers Icon_minitimeSat Mar 23, 2013 9:38 pm
do you think yamaha will still honor the recall?
Yotehunter66
Moderator
Yotehunter66
wheel spacers Empty
PostSubject: Re: wheel spacers   wheel spacers Icon_minitimeSat Mar 23, 2013 10:13 pm
I'm wondering the same thing. I'll have to call them.
wheel spacers Empty
PostSubject: Re: wheel spacers   wheel spacers Icon_minitimeSun Mar 24, 2013 12:24 am
i still have my complete sway bar
wheel spacers Empty
PostSubject: Re: wheel spacers   wheel spacers Icon_minitimeSun Mar 24, 2013 1:54 pm
the recall was for rollover tendency.
a few morons got hurt and sued yamaha for design flaws.
a wider stance in the rear (2" spacers) helps maintain a little more stability in the corners because it limits oversteer.
you will get more chassis flex without the sway bar.
wheel spacers Empty
PostSubject: Re: wheel spacers   wheel spacers Icon_minitimeSun Mar 24, 2013 2:34 pm
I like mine better wo the swaybar , better artic
Deuces wild
Deuces wild
wheel spacers Empty
PostSubject: Re: wheel spacers   wheel spacers Icon_minitimeSun Mar 24, 2013 5:36 pm
How much wider is it because I ride i pretty tight trails?
Rootin'Rhino
Rootin'Rhino
wheel spacers Empty
PostSubject: Re: wheel spacers   wheel spacers Icon_minitimeMon Mar 25, 2013 5:07 pm
I think they are 1" spacers so with stock wheels should be 2" wider, I never got mine because I run sra wheels with 27X12 laws on the back so its already about 6" wider than stock.
DesertRhino1301
wheel spacers Empty
PostSubject: Re: wheel spacers   wheel spacers Icon_minitimeWed Mar 27, 2013 5:17 pm
I just did mine two weeks ago. Yamah still did the 'volunteer upgrade' (sway bar and spacers). I like it better than before.
wheel spacers Empty
PostSubject: Re: wheel spacers   wheel spacers Icon_minitimeWed Mar 27, 2013 7:00 pm
i thought they were 2" spacers from yamaha. I like my rear sway bar
wheel spacers Empty
PostSubject: Re: wheel spacers   wheel spacers Icon_minitimeWed Mar 27, 2013 7:54 pm
The wheel spacers gave me a lot more stability on the tight trails.
cumnz
wheel spacers Empty
PostSubject: Re: wheel spacers   wheel spacers Icon_minitimeThu Mar 28, 2013 10:53 pm
Yamaha still honors the volunteer recall. The spacers are 2" per side, rear only.
wheel spacers Empty
PostSubject: Re: wheel spacers   wheel spacers Icon_minitimeFri Mar 29, 2013 1:05 am
I am back and forth on putting mine back on. I have larger offset wheels already so my rears stick out some already. If I put the spacers back on I am going to have to buy a new trailer.
wheel spacers Empty
PostSubject: Re: wheel spacers   wheel spacers Icon_minitimeFri Mar 29, 2013 1:54 pm
thanks for info on recall did not know there was one sounds like most like the spacers better than the sway bar will be calling local dealer today to see about it
wheel spacers Empty
PostSubject: Re: wheel spacers   wheel spacers Icon_minitimeFri Mar 29, 2013 5:57 pm
How much wider would it be to have a mid-travel installed compared to the spacers ?
wheel spacers Empty
PostSubject: Re: wheel spacers   wheel spacers Icon_minitimeFri Mar 29, 2013 7:49 pm
think i'm going to just buy 1" spacers, yamaha says they have to install bla,bla bla, have to trailer it to them, think i'll just eat the money and buy them myself
wheel spacers Empty
PostSubject: Re: wheel spacers   wheel spacers Icon_minitimeFri Mar 29, 2013 9:30 pm
I've got 2" spacers on all four corner of my bike and like them. I also put a 3" lift on which moved the rear shocks from the inside to the back side of the axles. With adding 27X14 wheels/tires I was looking at spreading the rubber on the ground out. My idea was, if I'm going up, I'm going to spread it out also. The lift and tires had to do with clearance but also with axle angle. I've also ran the bike with double 2" spacers on the back for a total of 8" spread and had zero problems with that. Looked badazz, and throw mud everywhere. Like a Star @ heaven
wheel spacers Empty
PostSubject: Re: wheel spacers   wheel spacers Icon_minitimeTue Apr 02, 2013 10:19 pm
Did the mods myself,2" billet rear spacers,removed my own sway bar because I had heard that the Yamaha dealers would have to keep the bar as part of the program. I feel on the trail the ride is softer and the suspension articulation is better. When hit the gas in the apex the Rhino slides out better,I think.
wheel spacers Empty
PostSubject: Re: wheel spacers   wheel spacers Icon_minitimeTue Apr 02, 2013 10:23 pm
They gave mine back and I didn't even ask.
wheel spacers Empty
PostSubject: Re: wheel spacers   wheel spacers Icon_minitimeTue Apr 02, 2013 10:27 pm
X2, Still laying in the garage someplace collecting dust. Like a Star @ heaven
wheel spacers Empty
wheel spacers
» Wheel Spacers and Wheel Bearings
» Spacers
» Bad wheel bearing?
» wheel studs
» Wheel bearings!!
