| Any tips on my 700 cam install | |
+3RHINOMOON REDRHINO64 jdsande3 7 posters |
jdsande3
Posts : 18 Join date : 2013-03-10
| Subject: Any tips on my 700 cam install Sat Mar 23, 2013 9:08 pm | |
| I just received my stage 2 700 rhino cam and power commander V controller from James for my 2012 rhino. Anyone have any good tips or a link to a good installation thread? Also, I didn't order the cam chain adjuster gasket, so I don't have it. Do you all think this will be needed for the install? Do I have to completely remove the chain adjuster? Thanks for the help and advice! | |
| Subject: Re: Any tips on my 700 cam install Sat Mar 23, 2013 9:15 pm | |
| James will chime in,he has done a ton of them. | |
RHINOMOON
| Subject: Re: Any tips on my 700 cam install Sat Mar 23, 2013 10:20 pm | |
| i removed the chain adjuster, when yer goin to remove the bolts from the cam shield n stuff, stuff a rag into where the chain is just in case a bolt drops, but to do it isnt that hard. there a vid kikin around somewhere. Good luck | |
| Subject: Re: Any tips on my 700 cam install Sat Mar 23, 2013 10:26 pm | |
| is the gasket in your koozie | |
jdsande3
| Subject: Re: Any tips on my 700 cam install Sat Mar 23, 2013 10:32 pm | |
| - WV Hot Rod Rhino wrote:
- is the gasket in your koozie
Ha! Why yes it is James. Thanks, didn't realize you gave me one. | |
| Subject: Re: Any tips on my 700 cam install Sat Mar 23, 2013 10:58 pm | |
| sweet...nikki is on it!!...mark the cam sprocket and chain with a silver marker so it will be easy to go back...just check it after you put it on to make sure...just a way to speed it up...still have to look at the marks | |
jdsande3
| Subject: Re: Any tips on my 700 cam install Sun Mar 24, 2013 11:24 am | |
| Ok, a little worried, just to make sure the cam I received is a raptor stage 1 cam, but for a 2006-2008 raptor 700. I know the raptor stage 1 is a rhino stage 2, but at the hotcams website, they have a different part number for the 2009-2013 raptor 700. I want to confirm there is no difference in the cam since I'm putting it in a 2012 rhino! Thanks! | |
| Subject: Re: Any tips on my 700 cam install Sun Mar 24, 2013 1:15 pm | |
| thats the one you need!!for the 13 models too!! | |
jdsande3
| Subject: Re: Any tips on my 700 cam install Sun Mar 24, 2013 3:10 pm | |
| Ok, one last question, before with my jbs sheave, 18 gr. weights and gold spring (running 26'' itp mayhem mud tires) I could do 48 mph. Got the cam installed, defeinitly more power, but hit rev. limiter at 50 mph. I thought I should hit close to 58 or so, is it the weights slowing me down, or is the rev limiter not set right? Thanks for any help. | |
| Subject: Re: Any tips on my 700 cam install Sun Mar 24, 2013 3:46 pm | |
| over drive flopped over... | |
jdsande3
| Subject: Re: Any tips on my 700 cam install Sun Mar 24, 2013 3:56 pm | |
| Even though I can hit 48 without cam? Not second guessing just asking. Can they flop though I haven't been In there since the sheave install? Thanks for the quick response. | |
| Subject: Re: Any tips on my 700 cam install Fri Mar 29, 2013 7:58 am | |
| Oh yes they can flop over easily... I just pulled mine apart to find everyone flipped..... might wanna inspect them and get them right so you can go.... WHOOPIEEEEEEEE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! | |
sls666
| Subject: Re: Any tips on my 700 cam install Tue May 14, 2013 12:44 pm | |
| im about to intall my cam this week is there anything i need to do with the valves? how about that vid? i never seen it but seen chrisH pics seem to have put things in a decent prospective | |
jdsande3
| Subject: Re: Any tips on my 700 cam install Tue May 14, 2013 4:55 pm | |
| You will have to adjust the valve lash (losen it up) to remove the cam. Once the new cam is installed, set the valve lash (the hot cam will come with the exact specification which is within the OEM spec). The one tip I would have is use a silver sharpie and mark in a couple locations the timing chain to the timing gear. This will make reinstallation a breeze. Let me know if there are any other questions. | |
| Subject: Re: Any tips on my 700 cam install Tue May 14, 2013 5:05 pm | |
| Be careful not to drop the deconpresion pin to. It is easy to do when you are pulling it out. | |
sls666
| Subject: Re: Any tips on my 700 cam install Tue May 14, 2013 5:25 pm | |
| ok i seen that little sheet of paper in the box thats why i ask what do i torque the bolts too also? | |
| Subject: Re: Any tips on my 700 cam install | |
