In total there are 31 users online :: 0 Registered, 0 Hidden and 31 Guests
What speed is to be expected Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
What speed is to be expected Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
What speed is to be expected Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
What speed is to be expected Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
What speed is to be expected Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
What speed is to be expected Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
What speed is to be expected Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
What speed is to be expected Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
What speed is to be expected Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
What speed is to be expected Vote_lcapWhat speed is to be expected Voting_barWhat speed is to be expected Vote_rcap
tofas4you
9 posters
tofas4you
What speed is to be expected Empty
PostSubject: What speed is to be expected   What speed is to be expected Icon_minitimeFri Mar 29, 2013 9:25 pm
I installed a Jbs sheave with 16 oz weights and purple spring with a dynotek cdi max speed was 42 mph changed spring to a gold spring and only getting 45 mph rhino is stock engine running 27 inch sti rocktane tires I'm I asking to much with a stock engine could my belt be bad I don't wanna lose my bottom end to gain speed
PostSubject: Re: What speed is to be expected   What speed is to be expected Icon_minitimeFri Mar 29, 2013 9:33 pm
how many miles on belt
tofas4you
PostSubject: Re: What speed is to be expected   What speed is to be expected Icon_minitimeFri Mar 29, 2013 9:40 pm
About 300 I talked to you on phone the several times still can not hit 60 I got passed by a wolverine last weekend on the road it seemed to have more bottom end and engine braking with the purple spring
PostSubject: Re: What speed is to be expected   What speed is to be expected Icon_minitimeFri Mar 29, 2013 9:41 pm
700 right
tofas4you
PostSubject: Re: What speed is to be expected   What speed is to be expected Icon_minitimeFri Mar 29, 2013 9:46 pm
Yes 2012 700
PostSubject: Re: What speed is to be expected   What speed is to be expected Icon_minitimeFri Mar 29, 2013 9:52 pm
i will be gone till monday ridn...call me then and im gonna make a list on yours till we get it right..
tofas4you
PostSubject: Re: What speed is to be expected   What speed is to be expected Icon_minitimeFri Mar 29, 2013 10:00 pm
Ok sounds good have a happy easter
PostSubject: Re: What speed is to be expected   What speed is to be expected Icon_minitimeFri Mar 29, 2013 10:16 pm
you too!!
PostSubject: Re: What speed is to be expected   What speed is to be expected Icon_minitimeSat Mar 30, 2013 12:43 am
Something can't be right. One of the things I noticed with mine is that the engine braking is every bit as good, if not a little better than stock.
Watch the video and make sure you got your weights in right.
James will fix you up, don't get discouraged.
tofas4you
PostSubject: Re: What speed is to be expected   What speed is to be expected Icon_minitimeSat Mar 30, 2013 7:41 pm
The weights are installed correctly and not flipped got to be something wrong my tires are real heavy 8 ply not sure what wrong James will fix it I'm sure of it
tofas4you
PostSubject: Re: What speed is to be expected   What speed is to be expected Icon_minitimeMon Apr 22, 2013 9:05 pm
Ok update I installed 14oz weights and purple spring can only get 43 mph what are the symptoms of you belt being bad ? James any ideas ?
PostSubject: Re: What speed is to be expected   What speed is to be expected Icon_minitimeTue Apr 23, 2013 2:40 am
Those are some real heavy tires, but I don't want to believe they would kill you that bad. I would think that it should hit the upper 40s pretty good.
You hitting the rev limiter at 43-45?
PostSubject: Re: What speed is to be expected   What speed is to be expected Icon_minitimeTue Apr 23, 2013 8:15 am
send me pics
PostSubject: Re: What speed is to be expected   What speed is to be expected Icon_minitimeTue Apr 23, 2013 10:43 am
I know with 18g and gold spring with 28's radials I was at 48 without CDI.
Switched to 16g and dropped to 44mph. I'm still learning but to me it seems like the tires hold you back alot.
I have 29.5 terminators with cam, msd and 16g and can only get 43 mph on a long stretch. Toss some smaller tires on it and see what you get.
PostSubject: Re: What speed is to be expected   What speed is to be expected Icon_minitimeTue Apr 23, 2013 11:13 am
I have to agree on the tire size, I can hit 50 mph on 25in tires with the Jbs sheave and 18 gram Od sliders, But when I put on my 27in MST Outlaws it drops to 44-45 mph. There is just too much weight in the bigger tires. my 2 cents.
chalkminer
chalkminer
PostSubject: Re: What speed is to be expected   What speed is to be expected Icon_minitimeTue Apr 23, 2013 1:04 pm
How are you measuring your speed? A taller tire will cause the speedo to read slower.
PostSubject: Re: What speed is to be expected   What speed is to be expected Icon_minitimeTue Apr 23, 2013 2:00 pm
I know in real world situations it will be off with the increase in tire size. Did anyone GPS to compaire? Would be a good write up
PostSubject: Re: What speed is to be expected   What speed is to be expected Icon_minitimeTue Apr 23, 2013 10:06 pm
Thanks for pointing that out, sometimes my brain just fart's when im thinking! What speed is to be expected 2016508534
PostSubject: Re: What speed is to be expected   What speed is to be expected Icon_minitimeMon Apr 29, 2013 9:00 pm
i have a 07 660 with pro tec dual exhaust k&n intake an cdi an i can hit 47mph on the speedo with two people n it on hottop an im running 29.5s swamplites an stock clutching right now
PostSubject: Re: What speed is to be expected   What speed is to be expected Icon_minitimeMon Jun 24, 2013 12:13 pm
Before my JBS I had CDI, gold spring and yamaha 14gram weights and could run 51mph with 26" big horns on 14" wheels and lots of other accessories like a front rack that weights 70lbs and a winch. Now after the JBS sheave and 18gram OD weights and gold spring I have been up to 57mph. All GPS and my dash actually reads the same as GPS most of the time with 1mph +- on occasion.
PostSubject: Re: What speed is to be expected   What speed is to be expected Icon_minitimeMon Aug 05, 2013 12:06 am
I had to come home part way along a hyway and reached 60MPH,thats the fastest I have ever gone on my Rhino,I might have been able to go faster but the RPM's sounded high so I slowed to 54.
» 700 top speed
» 700 top speed
» my 660 top speed run 30 to 54 mph
» 450 Speed/What Am I Missing?
» 660 Top speed what am I missing?
