| Mounting Siphon Break | |
+3onebuilder Firefighter CUSTOMIZEDRHINO13 7 posters |
| Subject: Mounting Siphon Break Tue Apr 09, 2013 8:27 pm | |
| I have seen people mount there siphon breaks different ways what's the best way? | |
| Subject: Re: Mounting Siphon Break Tue Apr 09, 2013 9:13 pm | |
| It should not be mounted the way I did. It should be mounted in such a way that any oil caught in the tank would run back into the motor when the engine is off. | |
| Subject: Re: Mounting Siphon Break Tue Apr 09, 2013 9:23 pm | |
| Tube from the crankcase goes into bottom of the siphon break. The vent tube goes toward the front of the rhino, zip tie the filter onto the ebrake cable. Make sure the lowest port is hooked onto the crankcase tube so all oil will return to engine. | |
| Subject: Re: Mounting Siphon Break Tue Apr 09, 2013 9:40 pm | |
| Very important to make sure there is no kinks in the hose or that the zip ties are not to tight it is a vent line and you will build pressure in the case if it can't breath and can even build enough presure to push your oil dipstick out. | |
| Subject: Re: Mounting Siphon Break Wed Apr 10, 2013 9:37 am | |
| - CustomizedRhino13 wrote:
- I had it mounted different but I think this way will work.
That installation is correct. I see you are running the OEM intake snorkel, have you heard of the RAIS mod? | |
| Subject: Re: Mounting Siphon Break Wed Apr 10, 2013 11:35 am | |
| Yes but I don't quite understand it? | |
| Subject: Re: Mounting Siphon Break Wed Apr 10, 2013 12:15 pm | |
| But you was nice enough to fix it for me. | |
| Subject: Re: Mounting Siphon Break Wed Apr 10, 2013 12:54 pm | |
| - T.Rhino wrote:
- But you was nice enough to fix it for me.
well i figured it was the least i could do for somebody with a slow ass rhino..lol | |
| Subject: Re: Mounting Siphon Break Wed Apr 10, 2013 1:41 pm | |
| Ohh boy that was wrong. Well I know for sure I can smoke your ass right unless you got some Fred flinstone in your blood. | |
| Subject: Re: Mounting Siphon Break Wed Apr 10, 2013 7:40 pm | |
| ok help the dummy out whats the RAIS mod where can I see one | |
| Subject: Re: Mounting Siphon Break Wed Apr 10, 2013 7:42 pm | |
| Subject: Re: Mounting Siphon Break Wed Apr 10, 2013 7:57 pm | |
| Subject: Re: Mounting Siphon Break Wed Apr 10, 2013 8:50 pm | |
| Thanks I have one of those.Do you have to rejet? | |
| Subject: Re: Mounting Siphon Break Wed Apr 10, 2013 9:46 pm | |
| Nevermind I read the thread again. | |
| Subject: Re: Mounting Siphon Break | |
