Who is online? | In total there are 29 users online :: 0 Registered, 0 Hidden and 29 Guests :: 1 Bot None Most users ever online was 207 on Tue Jun 11, 2013 11:13 pm |
| | cv joints | |
+7EddieMc kronik CUSTOMIZEDRHINO13 sls666 08Rhino450SE txgrown1404 Bumpers 11 posters | |
Bumpers
| Subject: Re: cv joints Sat Apr 27, 2013 10:47 pm | |
| Cool I will chck with them.. seem to be less breakage? Also what about stars and ball bearings I want to go ahead and rebuild both of the rears so I know they are good | |
| | | kronik
Posts : 27 Join date : 2013-04-23 Location : Smoke dope, eat soap, fly high on a bubble...
| Subject: Re: cv joints Mon Apr 29, 2013 3:43 pm | |
| - Swampdonkey wrote:
- True fact about the girl that answers the phone. She put me on with a guy that said my diff was the problem. I don't have a rear diff brace yet. Still shopping. I've managed to tear the axle seal twice now and the axle end looks trashed now. So I do need something done. I did buy these because I am hard on chit and managed to not tear them up on my brute force.
It's not the lack of a rear diff brace that's causing these axles to come out... It's not doing you any favors, but that's not the cause either. I hear ya on having to replace the axle seals when they pull out, I mean that's almost a given that that part gets wrecked every single time it happens. A lot of times though, it also can take a chunk out of the rear diff from the seal housing (thereby making a new seal not be able to stay in place without something like JB Weld smeared around the break after you put the new seal in place...). As a side note, when I had to move to Gorilla axles, I stopped using the factory dust covers as well. I mean you can put them on the Gorilla axles, they will fit and still go into the spool, just that I no longer use them at all. They're a great axle, even though I break them, but mine don't pull out because mine are the correct length now. | |
| | | kronik
| Subject: Re: cv joints Mon Apr 29, 2013 3:45 pm | |
| - Bumpers wrote:
- I will sell them later on once i get my issues fixed. But right now im holding on to them just incase i need them.
I talked with the ppl at gorilla and they told me its a common problem with their axles pulling out of the diffs. I was told to take a dremel and deepen the channel where the cir clip rides to hold them in. That come straight from the ppl at gorilla. I will call them and check on the cages. I really like the lighter stock cvs but if i have to i may have to run gorillas in the rear. All i know is i have about 1k in axles and none of them work at the moment lol I've heard about the "dremel" fix... It's a hack that won't compensate for anything. Fact is, if the inner CV slides into the spool all he way, the circlip (square or otherwise) will do its job on the stock spool. If your axle is pulling out of the diff/spool, you've got the wrong size axle. Gorilla can say whatever they want, but I mean aren't they located in the same town as Sy Robertson and Duck Commander? Can you imagine? I know I can after talking with them many times... "Hey! America is in too bigga rush. Lay back, sip a little tea, mow a little grass, YO', and if ya git tahred, take ya a litle nap. Work hard. Play hard. Nap hard. That's what I always say, Jack" Frig... My response to Gorilla is this: "Hey! Nappin' ain't fixin' mah ayyyxle length, YO'. Y'all need tah git back to work an' make 'em right, Jack, so's I can starts bein' HAPPAH HAPPAH HAPPAY." | |
| | | Bumpers
| Subject: Re: cv joints Tue Apr 30, 2013 12:22 pm | |
| well I called gorilla and they said they only have outer stock cv joint rebuild kits | |
| | | Bumpers
| Subject: Re: cv joints Tue Apr 30, 2013 7:59 pm | |
| just as I suspected | |
| | | RiverRat
| Subject: Re: cv joints Wed May 01, 2013 12:42 am | |
| Damn that's not good. And you can't get inner rebuilds through gorilla huh? | |
| | | Bumpers
| Subject: Re: cv joints Wed May 01, 2013 2:01 am | |
| The lady I talked with at gorilla said all they had were the outer joint rebuild kits......
Question. Empi heavy duty joints, whats the word on them ? I think ive decided I need limit straps as well to help end this problem | |
| | | rhino727
| Subject: Re: cv joints Fri May 03, 2013 1:10 am | |
| whats the stock axle length | |
| | | RiverRat
| Subject: Re: cv joints Sun May 05, 2013 5:59 pm | |
| 26" and 23.5". Those are stock axles on an 08 700. | |
| | | RiverRat
| Subject: Re: cv joints Mon Jun 10, 2013 1:05 pm | |
| I finally got home to work on my rhino and the gorilla axle is 3/4" shorter than stock. They say they are built different and don't need to be as long. I call BS. | |
| | | RiverRat
| Subject: Re: cv joints Tue Jun 11, 2013 12:40 am | |
| Measured my gorilla axle today and the shortest it was is 25' 3/4" and the the longest is 26' 5/8". The factory axle is 26". That doesn't add up. | |
| Subject: Re: cv joints | |
| | | | cv joints | |
