| Loose Ball Joints & Steering Stem | |
+5WV Hot Rod Rhino scottwv Jet CUSTOMIZEDRHINO13 Mrs. Hot Rod 9 posters |
Mrs. Hot Rod Admin
| Subject: Loose Ball Joints & Steering Stem Fri Apr 12, 2013 9:57 pm | |
| Subject: Re: Loose Ball Joints & Steering Stem Fri Apr 12, 2013 10:41 pm | |
| Subject: Re: Loose Ball Joints & Steering Stem Fri Apr 12, 2013 10:55 pm | |
| - CustomizedRhino13 wrote:
- Is that Jets rhino?
yes sir, that is the rhinojet. | |
| Subject: Re: Loose Ball Joints & Steering Stem Sat Apr 13, 2013 8:24 am | |
| Damn Jet , Hot-rod has already ragged-out your ride "testing" it !!!... | |
| Subject: Re: Loose Ball Joints & Steering Stem Sat Apr 13, 2013 9:03 am | |
| 9 out of 10 rhinos i work on has a loose steering stem....all models...takes alot of play out of the steering wheel too!!! | |
| Subject: Re: Loose Ball Joints & Steering Stem Sat Apr 13, 2013 9:29 am | |
JBFIREMAN
| Subject: Re: Loose Ball Joints & Steering Stem Sat Apr 13, 2013 9:38 am | |
| THANKS FOR THE HEADS-UP Hope you two have a great weekend | |
| Subject: Re: Loose Ball Joints & Steering Stem Sat Apr 13, 2013 4:00 pm | |
| Haha I new it, lookin good jet, those doors look awesome! | |
| Subject: Re: Loose Ball Joints & Steering Stem Sat Apr 13, 2013 7:56 pm | |
| I will check mine out. Thanks for the heads-up. | |
| Subject: Re: Loose Ball Joints & Steering Stem Sun Apr 14, 2013 5:26 pm | |
| Everyone go check yours NOW PLEASE. My tierod ends and steering stem were tight. Upper drivers side balljoint was seated, but the nut wasn't tight at all. The other three were not seated down on the control arms at all. One was pretty tight, but not seated down all the way. I sprayed some PB blaster on them to help them press into place. I got almost two whole turns of the nut on one of them. I'm thinking maybe the hole is rough or has burrs not letting them seat all the way before they reach the proper tq on the nut at the factory. It's nothing new, I remember hearing of a few grizzlys with the same deal back in 07 when I had one. | |
| Subject: Re: Loose Ball Joints & Steering Stem Mon Apr 15, 2013 1:02 am | |
| glad you got it fixed...mine was like that in 09....tightened everything then and it all lasted a long time!! | |
| Subject: Re: Loose Ball Joints & Steering Stem Mon Apr 15, 2013 6:20 pm | |
| Upper and lower ball joints on both sides not tight. Thanks for the heads up! | |
| Subject: Re: Loose Ball Joints & Steering Stem Mon Apr 29, 2013 1:26 am | |
| Subject: Re: Loose Ball Joints & Steering Stem Mon Apr 29, 2013 1:12 pm | |
| checked mine this morning driver side loose upper an lower shit this is really mucked up , look how many have found thiers loose holy shit , again thanks for the warning | |
| Subject: Re: Loose Ball Joints & Steering Stem | |
