| Clutch knocking sound | |
+6willykiller SteveS Polarblu chuddly WV Hot Rod Rhino Junglerider 10 posters |
Junglerider
Posts : 30 Join date : 2013-03-10 Location : Uvita Costa Rica
| Subject: Clutch knocking sound Tue May 21, 2013 1:41 pm | |
| I have a clutch that makes a knocking sound as it slows down and stops spinning. It's all stock. It sounds like the weights banging around. I took it apart and everything looks good, rollers are round, no wear on the sheave, added a bunch of Ultramatic grease like they come with from the factory, and it still knocks. Otherwise it preforms well. Anybody have any ideas?
I'll try to attach a video if I can figure out how.
Thanks | |
| Subject: Re: Clutch knocking sound Tue May 21, 2013 1:52 pm | |
| Subject: Re: Clutch knocking sound Tue May 21, 2013 2:23 pm | |
| mine does the same kind of thing (i think its the same thing) When i let off the gas it makes what i would call a "heavy rattle" doesnt sound like sheet metal or anything but like something much more substantial . | |
Junglerider
| Subject: Re: Clutch knocking sound Tue May 21, 2013 2:54 pm | |
| Subject: Re: Clutch knocking sound Tue May 21, 2013 3:00 pm | |
| see if the grease cover screws are hitting the cage | |
Junglerider
| Subject: Re: Clutch knocking sound Tue May 21, 2013 4:05 pm | |
| - WV Hot Rod Rhino wrote:
- see if the grease cover screws are hitting the cage
No, not hitting. Everything seems to be working smoothly. It sounds like maybe the weights are rolling in before the camplate does, allowing a little room for them to bang around. I'm checking the secondary spring next. | |
The author of this message was banned from the forum - See the message |
Polarblu
Posts : 30 Join date : 2013-05-18
| Subject: Re: Clutch knocking sound Tue May 21, 2013 4:41 pm | |
| Mine does the same but just one clunk every time I let off from full throttle. I figured it was just the sheaves slapping together.......... | |
Junglerider
| Subject: Re: Clutch knocking sound Tue May 21, 2013 4:57 pm | |
| - Polarblu wrote:
- Mine does the same but just one clunk every time I let off from full throttle. I figured it was just the sheaves slapping together..........
Yea, a lot of them do it but they're not supposed to. I'm trying to figure out why. Secondary spring is within spec. cleaned, greased the secondary.....still doing it. What next? | |
| Subject: Re: Clutch knocking sound Tue May 21, 2013 5:01 pm | |
| - Junglerider wrote:
- No, not hitting. Everything seems to be working smoothly. It sounds like maybe the weights are rolling in before the camplate does, allowing a little room for them to bang around. I'm checking the secondary spring next.
Hmmm, Is it possible that one weight is hanging up? That would create the clearance for the remaining weights to rattle around. | |
Junglerider
| Subject: Re: Clutch knocking sound Tue May 21, 2013 5:11 pm | |
| Hmmm, Is it possible that one weight is hanging up? That would create the clearance for the remaining weights to rattle around.[/quote]
I don't think so. I don't even have to rev it up enough for the primary sheave to move inward. Maybe one weight is heavier or lighter than the others? Guess I'll pull it apart, again.
Thanks for all the input.
willykiller
Posts : 5 Join date : 2013-03-12 Location : Ottawa, Canada
| Subject: Re: Clutch knocking sound Fri May 31, 2013 12:32 am | |
| Did you find out anything about the clutch knocking.......... | |
Polarblu
| Subject: Re: Clutch knocking sound Fri May 31, 2013 12:50 am | |
| I found my knock on deceleration was the diff mount upper. Cleaver guy that sold it to me put jb weld in to take up the space. Simple drill out, pound a sleeve in. | |
| Subject: Re: Clutch knocking sound Fri May 31, 2013 11:49 am | |
| Why was it knocking when you revved it in neutral? | |
| Subject: Re: Clutch knocking sound Fri May 31, 2013 11:56 am | |
Junglerider
| Subject: Re: Clutch knocking sound Wed Jul 10, 2013 11:54 am | |
| I took the wet clutch out, checked everything, and reinstalled it. The knocking went away after that. I still don't know what it was but it's gone now. | |
| Subject: Re: Clutch knocking sound Thu Jul 11, 2013 2:56 pm | |
| my rear diff comes loose everyother ride i lock tight it this time an seems to be holding so far is that a common thing for these? the mounts look a little cheap for holding a diff in place. | |
| Subject: Re: Clutch knocking sound Thu Nov 07, 2013 12:53 pm | |
sheaves slapping together..lmao.you wanna talk about what i do and copy me and you dont know shit...lol | |
| Subject: Re: Clutch knocking sound Thu Nov 07, 2013 1:53 pm | |
| Lol, slapping together like his pelvis on todds ass..... | |
| Subject: Re: Clutch knocking sound Thu Nov 07, 2013 2:36 pm | |
| Now that's funny stuff. I don't care who you are. | |
| Subject: Re: Clutch knocking sound | |
