| Right side knuckle/ spindle needed | |
slomo
Posts : 48 Join date : 2013-03-12 Age : 50 Location : Sherwood park Alberta
| Subject: Right side knuckle/ spindle needed Sun May 26, 2013 11:48 pm | |
| Felt a pull and was 6 km from camp thought I would limp it back and the bearing came apart, took out the knuckle as well so was looking for a right side knuckle or a aftermarket set of front knuckles thanks | |
| Subject: Re: Right side knuckle/ spindle needed Mon May 27, 2013 12:07 am | |
| i have new oem in stock....150.00 | |
slomo
| Subject: Re: Right side knuckle/ spindle needed Mon May 27, 2013 12:09 am | |
| Does it come with bearings and seals or bare James | |
| bearings seals and ball joint | |
slomo
| Subject: Re: Right side knuckle/ spindle needed Mon May 27, 2013 12:12 am | |
| Will PayPal you tomorrow thanks!!! I'll call as well about shipping to try and see what options on shipping to get it for the weekend thanks again | |
slomo
| Subject: Re: Right side knuckle/ spindle needed Mon May 27, 2013 10:48 pm | |
| Subject: Re: Right side knuckle/ spindle needed Wed Sep 18, 2013 8:44 pm | |
| think i need right front & right rear. got a wobble in both  rear is worse. will i need any special tools if i get the assemblies? | |
| Subject: Re: Right side knuckle/ spindle needed Wed Sep 18, 2013 9:32 pm | |
| nope and they last longer too | |
| Subject: Re: Right side knuckle/ spindle needed Wed Sep 18, 2013 9:56 pm | |
| i'll take one of each, please. how quickly could i get them | |
| Subject: Re: Right side knuckle/ spindle needed Wed Sep 18, 2013 10:57 pm | |
Posts : 1317 Join date : 2013-03-25 Age : 60 Location : musella,Ga.
| Subject: Re: Right side knuckle/ spindle needed Wed Sep 18, 2013 11:34 pm | |
| James , do you carry bearing/seals to rebuild knuckle or do you think they don't hold up | |
| Subject: Re: Right side knuckle/ spindle needed Wed Sep 18, 2013 11:47 pm | |
| i do have them...after they rust inside or real high mileage its better...its also less labor to install if your paying somebody or dont have the extra time yourself | |
| Subject: Re: Right side knuckle/ spindle needed Thu Sep 19, 2013 12:26 am | |
| this is what you need, maybe I cursed all the stock spindles...lol | |
| Subject: Re: Right side knuckle/ spindle needed Thu Sep 19, 2013 10:13 am | |
| Subject: Re: Right side knuckle/ spindle needed Thu Sep 19, 2013 11:06 am | |
| - ASPENDELL ROVER wrote:
- this is what you need, maybe I cursed all the stock spindles...lol
you definitely have a great setup, JP! too much high dollar stuff for me though lol. the way i ride i would have that stuff totalled the first time i hit the trails | |
| Subject: Re: Right side knuckle/ spindle needed Thu Sep 19, 2013 11:10 am | |
| - WV Hot Rod Rhino wrote:
- i can ship it tomorrow
need right front and right rear assemblies. all i will need is a pickle fork for the tie rod, right? is there anything else that would cause a wobble other than bearings or if i take a long hike? definitely will replace the rear before the ride; will prolly bring the front with me to the ride JIC pm sent to the boss | |
| Subject: Re: Right side knuckle/ spindle needed Thu Sep 19, 2013 11:16 am | |
| knuckle bushing in the rear will make it wobble...... | |
| Subject: Re: Right side knuckle/ spindle needed Thu Sep 19, 2013 11:24 am | |
- knuckle bushing in the rear will make it wobble......
so i would need to replace the entire assembly? | |
| Subject: Re: Right side knuckle/ spindle needed Thu Sep 19, 2013 11:30 am | |
| if the bearings is bad too i would | |
| Subject: Re: Right side knuckle/ spindle needed Thu Sep 19, 2013 11:31 am | |
- if the bearings is bad too i would
ship it | |
| Subject: Re: Right side knuckle/ spindle needed Thu Sep 19, 2013 1:09 pm | |
you definitely have a great setup, JP! too much high dollar stuff for me though lol. the way i ride i would have that stuff totalled the first time i hit the trails Thanks Denny, but my goal with this"high dollar stuff"..lol, is to not break things and be confident in my set-up since I ride by myself 95% of the time with my wife and kid | |
| Subject: Re: Right side knuckle/ spindle needed | |
