In total there are 66 users online :: 0 Registered, 0 Hidden and 66 Guests :: 1 Bot
help adjusting the gear select shifter Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
help adjusting the gear select shifter Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
help adjusting the gear select shifter Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
help adjusting the gear select shifter Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
help adjusting the gear select shifter Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
help adjusting the gear select shifter Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
help adjusting the gear select shifter Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
help adjusting the gear select shifter Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
help adjusting the gear select shifter Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
help adjusting the gear select shifter Vote_lcaphelp adjusting the gear select shifter Voting_barhelp adjusting the gear select shifter Vote_rcap
2 posters
Snorider
help adjusting the gear select shifter Empty
PostSubject: help adjusting the gear select shifter   help adjusting the gear select shifter Icon_minitimeTue Aug 27, 2013 9:34 pm
My rhino has always been very precise on the L-H-N-R. it was very easy to put it into any spot. But past couple rides it has been pretty finicky about finding the gears and staying there. especially finding neutral.  I thought I saw how to adjust that linkage somewhere earlier, looked and couldn't find it.  Could someone help me out on this please. sucks when your dropping down a canyon wall and it kicks out of low range half way down:|
PostSubject: Re: help adjusting the gear select shifter   help adjusting the gear select shifter Icon_minitimeTue Aug 27, 2013 10:12 pm
Sound like the detent is worn or damaged. To adjust the linkage loosen the rod ends remove one end and place the shifter in neutral, adjust the ends so that they line up as good as you can and then put it back together.
» 09 700 ring gear and pinion
» ADJUSTING VALVES
» adjusting tps on 700 rhino
» Reverse gear upgrade
» middle drive gear
HOTRODRHINOFORUMS.COM :: Technical :: drivetrain-
