Who is online? | In total there are 17 users online :: 0 Registered, 0 Hidden and 17 Guests :: 1 Bot None Most users ever online was 207 on Tue Jun 11, 2013 11:13 pm |
| | Change to 12g OD's ?? | |
| Subject: Change to 12g OD's ?? Sat Sep 21, 2013 10:33 pm | |
| So I'm thinking on changing my 14 g ODs to 12g to get more low-end. Is anybody running 12s? It's just when I hit the thick mud, I can barely turn them to get through. | |
| | | WV Hot Rod Rhino Admin
| Subject: Re: Change to 12g OD's ?? Sat Sep 21, 2013 11:27 pm | |
| i love 12s in a 450...do you have a aftermarket cdi | |
| | | Kenny G
| Subject: Re: Change to 12g OD's ?? Sat Sep 21, 2013 11:45 pm | |
| Evan, I tried 14, 12, & 10's with different springs and found for my 450 the 12gr and Blue spring gave me the best low-end and high-end. | |
| | | honda450sfm
| Subject: Re: Change to 12g OD's ?? Sun Sep 22, 2013 12:41 am | |
| I have a 660 with stock cdi. I do have Copperhead CDI sitting in a box on the shelf but never needed it since I don't hit the rev limiter too often. I grounded the reverse light to the block, will that remove the rev limiter? Think I should try the 12g? | |
| Subject: Re: Change to 12g OD's ?? Sun Sep 22, 2013 9:11 am | |
| | | honda450sfm
| Subject: Re: Change to 12g OD's ?? Mon Sep 23, 2013 12:35 am | |
| 26" Bighorns. Let me know what you think James. I need to order some other parts too so I'll do it all in one order. What's the best way to order, phone or email or pm? | |
| | | honda450sfm
| Subject: Re: Change to 12g OD's ?? Sat Oct 05, 2013 9:57 pm | |
| So I talked to James about my set up and what I wanted. He suggested i stay with the 14g OD's, put a purple spring in the secondary and use my aftermarket cdi. Got it all in today and took it for a drive and I must say, that was some good advise! I now have that low end from 0-10 km. It takes a while longer to get to my top end but I have way more torque on the low end which is where I wanted it. I made a run with stock cdi and then with my copperhead cdi. Never hit the limiter with either one but then again I only had the length of a soccer field to test it out. Wondering if I should stick with the stock cdi or aftermarket. Is revving this ol 660 detrimental to its lifespan? | |
| Subject: Re: Change to 12g OD's ?? | |
