CamoRhino660
| Subject: Couple of questions Sun Sep 29, 2013 7:57 pm | |
| Hey Flimmy I have a 10" led bar and was wondering if I would need that harness you have on the site or if I can just run it from the battery threw the switch to the light? Also was wondering if you have a fan over ride kit?
Thanks for any and all help! | |
| Subject: Re: Couple of questions Sun Sep 29, 2013 10:22 pm | |
| No you don't need a wiring harness. The 10" sr only draws 2.4 amps. Just run the wire from the batt. to a 5 amp fuse then to your switch then the light.
No I don't have a fan over ride kit. | |
| Subject: Re: Couple of questions Sun Sep 29, 2013 10:24 pm | |
| One more thing make sure your switch is rated at least 10 amp. I like to run a switch that is 1.5x's what the light will draw if your not running a relay. | |
CamoRhino660
| Subject: Re: Couple of questions Sun Sep 29, 2013 10:36 pm | |
CamoRhino660
| Subject: Re: Couple of questions Sun Sep 29, 2013 10:39 pm | |
| You no how to wire up a fan over ride so I don't have to buy one? | |
| Subject: Re: Couple of questions Sun Sep 29, 2013 10:45 pm | |
| No , but I'm sure Steve S probably does. Try posting in the wiring section | |
| Subject: Re: Couple of questions | |
