Who is online? | In total there are 8 users online :: 0 Registered, 0 Hidden and 8 Guests :: 2 Bots None Most users ever online was 207 on Tue Jun 11, 2013 11:13 pm |
| | couple of belt / clutch questions | |
4x4ff
| Subject: couple of belt / clutch questions Thu Jun 13, 2013 11:14 am | |
| Some very newb questions here.
When I go to install my new belt which direction do the arrows go? I assume as there is an arrow on the belt housing pointing to the rear that is the direction the arrows on the belt would point when they are on top??
What should I lube the 'pilot' bearing in the cage over the primary with?? Should it be grease or oil??
Anything special to lube on the secondary prior to installing it back???
Thanks,
Steve | |
| | | 123.bert0621
| Subject: Re: couple of belt / clutch questions Thu Jun 13, 2013 11:43 am | |
| I put mine on clockwise,lasted 5,000km, used Yamalube on the secondary,primary and pilot bearing. Hope this helps. | |
| | | 123.bert0621
| Subject: Re: couple of belt / clutch questions Thu Jun 13, 2013 11:51 am | |
| Dirt Wheels magazine shows the belt arrows going forward? | |
| | | 4x4ff
| Subject: Re: couple of belt / clutch questions Thu Jun 13, 2013 11:57 am | |
| - 123.bert0621 wrote:
- I put mine on clockwise,lasted 5,000km, used Yamalube on the secondary,primary and pilot bearing. Hope this helps.
Yamalube.....oil? or ultramatic? Steve | |
| | | 123.bert0621
| Subject: Re: couple of belt / clutch questions Thu Jun 13, 2013 12:02 pm | |
| Rhino forum says arrows to the rear direction.Ultrumatic. | |
| | | WV Hot Rod Rhino Admin
| Subject: Re: couple of belt / clutch questions Thu Jun 13, 2013 12:06 pm | |
| | | 4x4ff
| Subject: Re: couple of belt / clutch questions Fri Jun 14, 2013 2:02 am | |
| Subject: Re: couple of belt / clutch questions | |
